Question about GE Refrigerators
Cleaned interior now getting warmer instead of colder
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
How do make my mini fridge colder there is a knob from 1- 10 is lower colder or warmer
Hi!
Here's an answer for you:
Setting the fridge knob to 10 will get it to the coldest possible
That means, lower is WARMER
Best regards!
Aug 09, 2011 | Sunbeam Refrigerators
Freezer works fine but refrigerator side is not cooling
yes ok. try the control to your right and it should say like freezer colder and warmer. by making the freexer a little warmer it will make the ref. colder. u r just turning a baffle so more cold air from the freezer will go into the ref, to make it colder.. ok
Feb 13, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
We have a delonghi pinguino pac-t105 which just doesnt get very cold.
Instructions Things You'll Need:
  • Clean cloth(s)
  • Garden hose (if necessary)
  1. Verify that the air conditioner is connected to a power supply if the unit is not operating. Reset the circuit breaker or fuse if necessary and ensure that the electrical cord is plugged firmly into the unit.
  2. Clean the condenser coil with water from a garden hose and wipe down the fan motor blades with a clean cloth if the air conditioner is flashing a yellow alert light or is not operating or cooling as expected. Remember to turn off and unplug the air conditioner prior to maintenance.
  3. Adjust the thermostat to a warmer setting if the air conditioner is producing air that is too cold. Adjust the thermostat to a colder setting if the air conditioner is not producing enough cold air. Allow a few hours for the colder or warmer setting to take effect.
  4. Clean away leaves, dirt, branches or other debris away from the main unit if the air conditioner is not functioning well or the motor is running excessively. Clean the grilles and vents to allow for proper air flow.
  5. Contact an authorized service professional if the above steps do not resolve the issue
Jan 17, 2011 | DeLonghi Heating & Cooling
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
Our Superba side by side has stopped cooling on both sides. We've cleaned the coils at the bottom of the fridge from the front panel. There continues to be a clicking sound, but the interior is not...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
On the True GDM12, is #1 colder or warmer than #5?
1 is warmer. The warmest setting is 1 the coldest is 9. Most of my customers use a setting of 5. A few are on 3 but they seem too warm to me.
May 13, 2010 | True GDM-12 Refrigerator Commercial
Lec freezer if i turn thr temperature up the red light starts to flash
that is because when you want a colder unit the sensor is detecting a warmer interior hence red warning light comes on.leave it at the setting you want and within 24 hours the red light will go off.
strongly recc you use a freezer temp gauge so you dont get rock hard ice cream(-18C is best)
Mar 23, 2010 | Freezers
Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
Jun 16, 2009 | NewAir ACP-1600H Portable Air Conditioner
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
