Question about Solis Palazzo Espresso Machine
Solis Palazzo stuck with lights and clean button blinking. Is there a master reset for the electronics?
  • bansheracer Oct 25, 2010
    Which lights?
    Have you ever pushed and held the clean button on the left? This button comes on every 250 coffees and will not let the machine continue until it has been cleaned. You are suppose to use the Soli tab that came with the machine. You drop it down the by pass chute, then push the clean button
4 Suggested Answers
SOURCE: Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Posted on Feb 12, 2008
SOURCE: Solis Palazzo Espresso Machine
My machine requires a much longer descaling cycle. So during the cycle I add another 2 quarts of water. This takes much longer, but seems to work for me.
Posted on Jan 11, 2008
  • 1089 Answers
SOURCE: brewer part for solis palazzo
Hi
What part do you need? I have some.
Posted on Jul 06, 2010
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Aug 04, 2011 | Solis Palazzo Espresso Machine
Three buttons keep blinking: clean, water and
Hi
First I would start off with priming the machine. Push the water button ( right button) open the steam knob and see if the light will clear? If it doesn't you have a restriction in your flow meter.
If light clears, go to the next light, which is the clean light (left button) Push and hold for 5 seconds until it starts then let it go until it clears. About 30 to 45 minutes.
Then you need to descale. If you have never done it email me.
Mar 13, 2010 | Solis Palazzo Espresso Machine
Solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
Led reads "ventilate". What do I do?
Hi
Ventilate means that you need to run water through the system.. Open the knob on the right side of the machine if it a Master 5000, or push the right button and light it up, then open the knob if its a Palazzo.
Aug 02, 2009 | Solis Coffee Makers & Espresso Machines
All leds flashing, after cleaning program
unplug it.... for about ten minutes or so
Mar 18, 2009 | Solis Palazzo Espresso Machine
Solis rapid Steam stuck in descaling cycle
try to run a new descaling to see if it works normal again.
/Mirran
Sep 22, 2008 | Solis Palazzo Espresso Machine
Solis pallazzo rapid steam
Hi Alex,
Try to prime the machine.
May 20, 2008 | Solis Palazzo Espresso Machine
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
May 29, 2007 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
178 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
