Question about Refrigerators
Comp. works but does not blow air in freezer so temp never drops.
    President:
  • 3,773 Answers
Check the evaporator fan in the freezer. You should be able to hear it running. Replace if not running.<br /> Thanks<br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a rel='nofollow' href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Posted on Aug 31, 2010
Freezer will not hold at freezer temprature 18degrees is dropping is currently at 6 degrees
Any Freezer does not stay at any one temp. If you freezer is part of your refrigerator then it goes through defrost and the temp will rise. When the compressor comes back on it will drop. How much food you have in your freezer will also be a factor. Not much food and the unit will flex widely in temp. too much food and the fan can not blow the coll air around properly and msy cause it to warm up. If you need more help please add additional information being very specific.
Mar 27, 2016 | Refrigerators
My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer has defrosted and Temp Alarm came on. Unplugged freezer and restarted it and turned cold lvl up. but still not freezing just blows cold air??
the comp is not running ( it sounds like . ) look for bad relay on compressor . or if ge a main control board .. mm
Aug 09, 2010 | Refrigerators
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
Aug 17, 2009 | Refrigerators
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer works, fridge doesn't
freezer ok no refrig???? do you here a fan on in the freezer sect when you open the freezer door?? common problem to have a bad evap fan motor and the unit will not blow the air up to the refrig compartment
Oct 27, 2008 | Maytag MBF2256H Bottom Freezer...
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
