Question about Acer Computers & Internet
Hello. Please help me...when I turn on the monitor after 2 or 3 seconds its turn off...It shows me the ACER log and then turn off I see a black screen...but de led is ligthing like normal funtion (green). I hvent any idea what to do...I change the capacitor but nothing....continues with the problem please help....:D
  • matamdp85 Aug 31, 2010
    JAJA I M SORRY.. I ONLY CHANGE TH 400 V 100uF CAP the model is Acer AL1711 desktop lcd monitor ... So let me see if I andertood u....you try to told me that I must chache all caps becouse they have diferents ERS betewn newones and the olders??? :P
    Pd: Jaja sorry if my inglish is not the best :D jajajajjaa UNLESS THANK U!!!!
  • 11,361 Answers
Did you replace the whole set of caps in the secondary DC power supply side? Bad caps can look normal but can have high ESR. See example of what happen when not all the caps in the DC side are not replaced: http://www.fixya.com/support/t5220798-three_hp_1702s_all_flicker
But again you may have problem in the inverter driving circuits such as bad IC or transistors, transformers, etc. Do you get all the 5vdc and the 12~16vdc?
Model number will help. Please post back.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Aug 31, 2010
  • Bud Martin
    Bud Martin Sep 02, 2010
    OK, so you replace the DC filter cap in the primary of the switching supply. Are you getting any DC voltages on the secondary side of the switching power supply. Send me pictures if you want, budmrtn@aol.com
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Acer monitor wont turn on or off?
This type of problem is usually caused by a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and repair the power supply board. If you can do a little soldering then you can repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2016w-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Nov 29, 2011 | Acer AL2016W 20" LCD Monitor
It keeps cutting of after a few seconds of logging on it will show the acer logo and then some of the program and then cut off.
Could you provide more detail? Is this happening when you turn on the computer, turn on the monitor, or when you log into Windows? If it's happening when you power on your monitor, it is likely not selecting the correct input. If your monitor has a button labeled "source" or "input" try pressing it.
Mar 16, 2011 | Acer Computers & Internet
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
ACER Al1916W goes blank in 3 seconds. It shows ACER splash screen for a sec., the desk top for .5 sec, then goes black. There is a very high pitch squeel each time there is any display. Power switch turns...
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Acer AL1916W 19" LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
