Hi, I have a boxlight cd-726c which is identical to eiki eip-25 and a megapower ML-620. It starts and projects fine for about 30 seconds then the color flickers and changes to white before it starts the cool down process for shutdown. What could it be? Thanks
  • ffrnklnn Aug 31, 2010
    The boxlight cd-726c is a DLP projector.
    President:
  • 1,768 Answers
Your LCD unit will need service.
1. It is a possible LCD controller that may be the problem iwth the "no picture .
2. you may have a logic issue at the inverter board .
3. There is a possible voltage drop at the rectifier module.
this can only be determined with Electronic testing equipment with a knowledgeable tech , there also may be certain component surrounding said electronics that may have direct cause and effect to the performance of your LCD tv.
Posted on Aug 31, 2010
Where can I find a service manual for the Eiki EIP-2500?
difficult to find online, try comparable model of SHARP XG-MB55X
May 24, 2012 | Eiki EIP-2500 Multimedia Projector
How to remove top cover of Eiki EIP-2500 projector
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
Eiki EIP 1600T projector will not power on. Projector was running when power went off for just a few seconds. Will not power back up now. I have power to projector.
inside there is a thermal fuse, that might be activated, because the cooling of the lamp did not happen after the power surge.
You need to remove the upper cabinet to reach, but do this very carefully !!
May 22, 2011 | Eiki EIP-1600T DLP Projector
Is it possible to connect a projector and a flat-screen tv and control both with a laptop computer? (the flat screen would be used instead of a projection screen)
when connected at the same time, you need an active signal splitter, or
connect the flat screen to the monitor out terminal of the EIP-2500.
Apr 03, 2011 | Eiki EIP-2500 Multimedia Projector
Our EIKI 4500 DLP projector work for about 40 mins then starts to power cycle. does it sound like the power supply to you. do you know where to get a replacement power supply for it?
This model has sometimes poor power supply boards.
replacing them is a terrible job, original boards are only available through official EIKI distributors.
partnumber = 9NK5600204232 ( manufacturer is SHARP)
Jan 11, 2011 | Eiki EIP-4500 DLP Projector Multimedia...
Need a new remote control for a EIKI EIP1. How do I order one? I am in Perth Western Australia
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Sep 20, 2010 | Eiki EIP-2500 Multimedia Projector
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Mar 07, 2009 | Eiki LC-X50M Projector
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
