Question about Kenmore Heating & Cooling
I have a kenmore central air unit model KAC024AK5. Fan started making noise few days ago. I'm still getting cold air. Opened the top grill and the fan is not loose. Could it be the motor and more specifically the bearing? If this is the case, should i get the motor repaired or get a new one from Kenmore Parts Canada? Your advise is greatly appreciated.\ gene
  • Kenmore Master
  • 43,501 Answers
Yes, the bearing go bad and for the price of the new motor I would get it new... to repair will be more then half that if they can ...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 31, 2010
I have an older amana central ac/heating unit, fan not turning outside, did pencil test, turns slowly then stops. changed capacitor a month or so ago all was fine. started making a humming noise so ran and...
Sounds like the fan motor has reached its endpoint. It will have to be removed and replaced. Find the dircuit breaker in your electric panel that supplies power to the air conditioner unit. When you have found the right one, even the humming sounds will be absent. The fan usually is at the top of the unit. You must have opened this to change the capacitor. Remove the fan band motor as a unit and take it to a store like Grangers and determine if they have a motor that would replace the one from your unit. If the motor has a model number on it, you may find a replacement available onlilne by Googling that number and the name Amana. Put electricians tape over the wires that led to the motor, just in case someone turns on the circuit breaker before you have completed the job
Oct 04, 2013 | Goodman CLQ36AR49 Air Conditioner
Central air conditoner outside unit
Well, the answer is yes. I have seen a bad capacitor cause a fan motor to run backwards. BUT..... After replacing the capacitor and WIRING it up the right way, everything should be fine. A lot of aftermarket condenser fan motors are reversible, so it can run counter-clockwise (CCW) or clock-wise (CW). However, most factory fan motors come one directional and on your specific unit, the air should always push out of the top. Running the unit with the fan going backwards will actually some-what do it's job, but damage other components like the compressor because it runs at higher operating pressures than what it is designed for.
Have someone else look at it! That's going to be the best advice I can give you. If they can prove that a capacitor caused the motor to permanently run backwards..... I want to know! Hope this helps and good luck with your unit.
Jun 22, 2012 | Heating & Cooling
We have a model 12AJA3601 in our daughters mobile home. It has stopped blowing cold air. The fan is working and air is blowing, but is not cold. It was fine a few days ago. I cleaned off the grills, but...
Possible low refrigerant charge.
Maybe also a compressor not performing correctly.
May sure all wires are secure in the t-stat especialy the yellow wire it calls for cooling at the compressor unit!
Oct 13, 2010 | Weather King 12AJA3601AH Air Conditioner
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
We have a Kenmore model 596.71864101 that is probably around 10 years old. The freezer is doing what it should but the refrigerator is not cooling. It did the same thing a few weeks ago, but suddenly...
There is a fan in the rear of the freezer that delivers cold air to the frig. Turn temp control down to make the freezer call for cold, the fan should also turn on, even if the door is open. This is an easy self install if it is the fan.
Jul 08, 2009 | Kenmore Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Not cooling at all
check for compressor running there were alot of start devices going bad a few years ago on whirlpool built units check that
Apr 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Heating & Cooling Logo
130 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
