Question about Harman Kardon SoundSticks II Computer Speakers
There is no sound from one of the two speakers... the one without the volume controls, how should i troubleshoot this?
  • 27,725 Answers
Try connecting the one with no sound to the connection that works
good luck
Posted on Aug 31, 2010
My system model no vt8366-8233 has not the system sound without external speakers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 27, 2011 | Computers & Internet
SOUND GOES UP AND DOWN WITHOUT TOUCHING VOLUME CONTROL
USE SOME SPIRIT OR WHITE PETROL ON THE VOLUME CONTROLER ITS JUST BECAUSE OF MOIST TURE AFTER USING SPIRIT TURN THE VOLUNE CONTROLER TO END AND TO MIN TWO THREE TIMES
Jun 10, 2010 | Dell ADA745 Computer Speakers
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Sound volume
have you tried a different set of speakers? you should be able to plug them into the headphone jack. speakers without a power supply are softer. my laptops the same way. i use vlc player when i play videos because you can turn the volume up to 200%.
Nov 16, 2008 | Computers & Internet
My harman/kardon speakers dont work
I was listening and the next minute the sound is gone. I no longer have the little 'speaker' icon on the lower right of my computer for volume control. How do I fix this?
Jun 17, 2008 | Harman Kardon HK206 Computer Speakers
No sound
What exactly is evrything?
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
Jan 04, 2008 | Behringer FCA202 - FireWire Audio...
Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external. Did you forget?
Nov 08, 2007 | Audio Players & Recorders
Lose of external speakers volume and balance controls
Hi Lescot, Did you re-installed it with XP deafult driver? if so, this is it! uninstall the driver, and reinstall the original manufacutre driver: [url=http://www.fixya.com/SftForumView.aspx?prdid=350345]click here[/url] good luck
Nov 19, 2005 | Creative Labs SoundBlaster Live! Sound...
Harman Kardon SoundSticks II Computer Speakers Logo
69 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
