Question about Bosch SHE4AM16UC 24 in. Built-in Dishwasher
Bosch SHE4AM16UC/01 tries to start a cycle but the clean light comes on after about one minute. I don't see any standing water in the tub and the screen for the fill valve appears to be clean. Any ideas?
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
  • 26 Answers
SOURCE: Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
Posted on Nov 12, 2008
  • 2692 Answers
SOURCE: Bosch dishwasher slowly fills with water after cycle is done
Replace the water fill valve, it's leaking.
Posted on Dec 21, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
Cycle stops after 2-3 minutes
Sounds like the fill solenoid. It is likely that the machine is stopping after a few minutes after not seeing the water level raise in the wash tank. When you say fiddle underside of the door, was this with any panels off? If so, maybe a loose wire on the pub that sends power to the solenoid.
Oct 30, 2017 | Bosch Dishwashers
Turn on dishwasher, goes to clean cycle right away.
My Bosch SHE4AM16UC was having the same problem of it going from active straight to clean, and there was water in the bottom making me think that there was either a clog or a pump issue. I took my shop vac sucked all the water out of the dishwasher including the down into the drain area for about 3 min until u think all the water is gone in the entire unit. Then I also took off the drain hose that was connected to either your sink or your disposal and held the shop vac over that area for about 5 min to get all the water and hopefully any clog that may be obstructing the drainage. Put the hose back on and hit start and it worked. So for me it was just a clog either deep in the hose or inside the unit. I hope this helps someone. TonyaB
Jan 19, 2011 | Bosch SHE4AM16UC 24 in. Built-in...
Water standing in plugged drain. Did rinse but water is still standing.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
New SHE4AM16UC, professionally installed eight months ago. Worked fine with very light usage until now. Dishwasher starts normally but stops and signals "clean" after less than five minutes on any cycle....
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 05, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch she4am16uc/01 not filling with water, can hear what I think is teh pump starting then it just sits there. Autoclean light just flashes and I cannot reset the dishwahser... any recommendations?
pull the dishwasher out and look inside the pan you more than likley have a leak and this is why it is not filling it has a safety so when it leak it will not fill with any more water.
Dec 27, 2009 | Dishwashers
Bosch SHE4AM16UC 24 in. Built-in Dishwasher Logo
110 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
