Inglis washer, Model #1FW7200TW; displays trouble code 0E (zero E) or code OE (letter O E) and water source will not shut off. Code is not included in the Instruction Manual provided. Can I get a full manual for the washer and what does this code represent.
SOURCE: Whirlpool Duet Washer Trouble Code F25
Best Solution is to return it and buy another kind like LG or something
Posted on Mar 01, 2008
SOURCE: error code oe
It means there is a drainage problem - either the drain hose is kinked or the filter is clogged
Posted on Oct 04, 2008
MNTECH
  • 1543 Answers
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Posted on Oct 15, 2008
  • 53 Answers
SOURCE: OE ERROR CODE APPEARS ON DISPLAY
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Posted on Oct 14, 2009
  • 572 Answers
SOURCE: lg washer oe code pump pluged
open panel small door on left front panel. empty water and clear pump.
Posted on Feb 13, 2010
Have a samsung washer model WA17XAR showing OE code and makes grinding sound and does not start
Hi this is a link to a short youtube video showing error code 0E, This washing starts and stops as well and the guy fixes it.....CHEERS..
https://www.youtube.com/watch?v=YOvFYcaLp8w
Mar 18, 2016 | Samsung Washing Machines
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
My Samsung front loader is taking in water and flashing 0E. Can you help tell me what my problem is? Thanks
An OE code (not 0E) is an overflow error. Too much washing powder/liquid may have been added. Turn off power, wait 30 seconds and turn on power again. You should hear the drain pump operate to drain the machine.
Feb 22, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
Kenmore Elite He washer code "OE"
The 0E code means the washer won't drain. It is usually a problem with something obstructing the pump, a kink in the drain line or the pump is burned out.
Jul 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Model Wm2496HSM will not spin and drain
Jodie, the OE fault is a drain problem. First thing to look at is the pump coin trap on the bottom of the washer behind the little door. If the washer has water in it, pull out the little hose, remove the stopped at the end and drain into a shallow bucket. When the water stops, removed the trap by twisting the trap handle counter clock wise. If it is full of "stuff" clean it and reinstall it. If it is clean, then you either have a bad pump or something stopping the pump.
Apr 10, 2014 | LG Washing Machines
I have an lg wd12650tp and it has stopped full of water with the code OE showing. I've tried emptying the filter at the front but it still wont drain? Any suggestions? btw apparently the code means...
Hi.
Error 0E is drain error.
Access the drain pump, located behind the service door at the base of the machine, in the front side, right below the washer door.
Disconnect power before starting the procedure.
Open the door and undo the pump attachment. Have a container ready to collect a good amount of water.
If that does not fix the problem, then there may be a fault. Further blockage, faulty pressure switch and faulty drain pump are the faults that can trigger error code 0E.
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Please click here to read an article showing how to fix common drain problems.
Regards.
Oct 21, 2011 | Washing Machines
F and H keep coming up on screen
The information provided is general. For information specific to your washer please resubmit the question, including the model number.
The "F" is at the beginning of all error codes. This indicates the a Fault has taken place. The second number or letter indicates what the Fault is.
FH : Is displayed when no water has been detected entering the washer.
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display
Unplug the washer from its electrical source and wait for 30 seconds.
Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
Check all hose connection and valves, both hot and cold, are turned on completely.
Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
Hope helps (remember to rating this free answer and leave a comment)
Sep 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washing displaying OE error code
here's a link to a service manual for you particular model seems OE is an overflow error, this will help you trouble shoot your problem. ( im current ly downloading this manual for my own reference )
http://www.servicematters.com/maytag_library/docs/16026186.pdf
Mar 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
382 people viewed this question
Top Washing Machines Experts
