Question about Dell Dimension 8200 PC Desktop
Older Dell 8200 will not power on. When plugged in the power light blinks amber, and it will not respond to the power switch. If I swap out the cpu for an extra celeron I have lying around the fans power up however nothing displays on the screen. I can't tell if the CPU's are the problem (bad original and the wrong replacement) or if the power supply has bit the dust since it does run when I do my experiment. Any ideas? P.S: I've removed the hard drives,RAM, and the CPU altogether - Same issue (blinking light, no fans, no response.) Thanks!!!!
  • 355 Answers
To better troubleshoot your issue take a look at the 4 diagnostic lights on the back of your PC, they will give you more information and possible solutions. HERE is the link to what the lights mean on your model PC.
Diagnostic Codes Your computer is equipped with four diagnostic lights, which are labeled "A," "B," "C," and "D" on the back of the computer. Each of the four lights can be yellow, green, or off as shown in the following table. When the computer is turned on or restarted and it is functioning normally, the lights flash during POST. After the computer starts, the lights remain green to signify normal computer operation.
If a malfunction is detected and the computer fails to start, the lights display a code that identifies the problem. Write down the diagnostic code displayed and look it up in the following table.
Posted on Aug 31, 2010
  • matt897 Aug 31, 2010
    unfortunately the lights on the back are ALL off. They do not even pop on for a second
  • Shawn DuRee Aug 31, 2010
    Blinking amber usually means
    A power supply or system board failure has occurred.
    Check the diagnostic lights to see if the specific problem is identified. Also, see "Power Problems" in your computer Owner's Manual.
    To be sure I would call Dell tech support and have them help you diagnose your problem. They are pretty good about support even if you PC is out of warranty.
Dell dimension 8200 help
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 09, 2014 | Dell Dimension 8200 PC Desktop
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
My power switch keep giving me a blinking amber light what can i do
Do you have a battery backup/surge protector?? Take it out of the loop and plug directly into the wall.
From DELL
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
Ensure that the processor power cable is securely connected to the system board
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Dell Dimension E520 PC Desktop
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX520 PC Desktop Problem
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Sep 04, 2008 | Dell OptiPlex GX520 PC Desktop
Dell GX280 no display
plug in a video card in a pci slot and see if your video comes on and do the same with your agp slot
Jan 25, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Dimension 8200 PC Desktop Logo
610 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
