RE: Kambrook KRH500 RADIUS Fan Forced Heater. Dear Sir/Madam, Please advise re the LOW and MED buttons engaging, but failing to function, i.e. no heating from these 2 functions. However, the HIGH and FAN buttons are responding normally. If requiring repairs/replacement parts please advise closest service centre or electrical service person to the St.Kilda area (Bayside) in Victoria. Hoping to hear from you very soon. Many thanks. Nina Landis
2 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: switches on Kambrook Radius fan
Super glue!
Posted on Sep 01, 2008
Dear Sir/Madam Could you please advise as to where
Dear sir i have problem with my sending email please help me
Thanks&Best regrads
Sep 19, 2013 | Computers & Internet
3500 propane forced air reddy heater not putting out much heat since I changed bottles
tank is being turned on to fast and the safety valve will close and not let the full pressure go to the burner same with any new tank that has the columbine valve in it pressure sensitive
Mar 25, 2013 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heater fan only works in HI position no low or med adjustment
The blower motor resistor has failed. A relatively in expensive repair.The resistor may have failed due to age or possibly the blower motor itself.
Jun 01, 2010 | 2002 Saturn Sl
2001 Mazda Tribute (3.0 L) Heater motor functions on high only
Its the Blower Resistor....If it was the switch, it probably wouldn't work at all....But the Resistor will give you those symptoms, of working on high med or low
Jan 19, 2010 | 2001 Mazda Tribute
Toyota tacoma heater fan runs slowly in the 3rd & 4th positions
Using a voltmeter, the resisted voltage values for the fan motor are as follows:
LOW- 3 VDC
Med LOW - 6 VDC
Med HIGH - 9 VDC
High - 12 VDC
The fan resistor gets 12 volts from each position of the fan switch, and the 12 VDC is then lowered thru each of the 3 internal resistors inside the fan resistor. My guess is that the resistor has failed, and the resistance wires contained on it may have meshed together. The resistor is on the black box between the blower motor housing and the center of the dash. 2 phillips screws hold it in. Easy to remove/replace. Hope this helps, and thanks for choosing FixYa.
Nov 23, 2008 | 1983 Toyota Camry
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heater blower works intermitantly
If you have access to a DC voltmeter; try this:
Check for voltage on each of the heater resistor terminals, when it is unplugged, key in the on position. With the heater switch on low, you should have 3 volts DC, on lo-med, 6 VDC, hi-med, 9 VDC and on hi, 12 vdc. It looks to me like you might have a bad heater switrch, if the voltages do not match exactly what is posted above, or vary when you slightly manipulate the switch, the switch contacts are bad. Hope this helps. If not, please repost for additinal info.
Oct 08, 2008 | 2000 Toyota Celica
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
