Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I have F&P DD603 with problem with bottom draw. Once a programme is selected and door is closed, the dishwasher beeps three times then tries to start itys cycle. It then starts but stops every 1-2 minutes (like pause botton has been pressed). If you press start again it starts for 1-2 mins then stops again. I have tried turning off the power and totally cleaned out the dishwasher but no change? Any suggestions?
    Brigadier General:
  • 3,513 Answers
Hi
When you pull out the drawer, pay attention to the bottom near the bottom front panel, you will see a little tab. this tab is at both sides of the drawer, press these tabs in and pull the drawer further a bit, you can see the tub move out a little further. Now lift the tube up and out ot the rails. Push the rail inside the dishwasher, then you will be able to put the drawer down on the floor. Don't try to pull the tube out so much since hoses are under the tube has a limited length.
This dishwasher has a diagnostics mode which can be entered but you need the service manual which is attached to the back wall inside the cavity ( you can see it if you pull the drawer all the way out but you cant reach it without removing the drawer from its roller guides.) You can enter the diagnostics mode by pushing keylock,and holding it in. Then push and hold start/pause in that order. If you push start pause first it just counts through a delay start.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 31, 2010
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
On 2 door dishwasher model DD603 bottom draw is very hard to slide out or in. Can i remove draw to inspect and oil draw runners?
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Default code F1
if you physically forced door open then started f1, its possible that there is no issue and you can reset it. F1 is a code for water leak... if you can remove the lower drawer from the cabinet, youll find water in the lower tray, youll need to dry up this water in order to have the f1 code stop
Nov 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw has no power
sounds like the actuator motors are stuck in the open position you can take a putty knike and try to pull the top down manually what is your email I can send you the service guide for the unit
Aug 13, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
73 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
