Question about NRS OTC 2006 Domestic, Asian and OBDII Smart Cable Super Bundle
2007 VW JETTA Code: P0480 Cooling Fan I Control Circuit Malfunction - The cooling fan stays on high speed after engine is turned off for approximately 45-60 seconds and then turns off. What are typical problems associated with this error code?
Please go to this site and write your experience about this ongoing problem with Volkswagen Jetta cooling fans.
http://www.ripoffreport.com/Auto-Warranty/-Volkswagen-of-Ameri/-Volkswagen-of-America-Poor-C-F95FA.htm
Posted on Oct 14, 2010
When i start my 2008 Cadillac sts i get a notification that engine hot A./C off. Even though it is the first time i stated it today
ENGINE HOT - AC OFF
Cooling System Description and Operation
you must have a cooling system problem of some sort !
Do the cooling fans come on when A/C is switched on ? Fan's should come on ! Does your vehicle have two or three cooling fan's ?
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Cooling
Having a qualified professional technician check it out would be your best bet ! Hooking up a factory or professional type scanner an check data input's an DTC'S - diagnostic trouble codes .
Diagnostic Starting Point - Engine Cooling
Begin the system diagnosis with the diagnostic system check. Refer to Diagnostic System Check - Vehicle . The Diagnostic System Check - Vehicle will provide the following information:
• The identification of the control modules which command the system
• The ability of the control modules to communicate through the serial data circuits
• The identification of any stored DTCs and their status
The use of the Diagnostic System Check - Vehicle will identify the correct procedure for diagnosing the system and where the procedure is located.
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active
DTC P2600: Auxiliary Coolant Pump Relay Control Circuit
DTC P2601: Auxiliary Coolant Pump Performance
DTC P2602: Auxiliary Coolant Pump Relay Control Circuit Low Voltage
DTC P2603: Auxiliary Coolant Pump Relay Control Circuit High Voltage
Dec 10, 2017 | Cadillac Cars & Trucks
What is the connection to a slipping transmission gears & code p0480 on my 2007 VW JETTA?
Because
When is the code detected? The P0480 code is detected when the Powertrain Control Module (PCM) detects that the commanded state of the driver and the actual state of the control circuit do not match.
Read more: https://www.engine-codes.com/p0480.html
P0480 Cooling Fan 1 Control Circuit Malfunction
I have one of these
BUY FIXD FIXD Automotive
Aug 07, 2017 | Cars & Trucks
FANS WONT COME ON ,,ALL FUSES,RELAYS AND ELECTRIC FAN MOTORS ARE NEW,,THERMOSTAT IS GOOD,,WHERE IS ELECTRIC FAN TEMP SENSOR LOCATION
op
why not post symptoms first and not a barrage of parts.
must we decode that to a symptom,. kinda hard right.
I will not guess. what is wrong, nor what is not working on your car. now what fans you are talking about, up to 4 fans on cars.
cab blower fan (wild guess blower is ok) and so is HVAC, ?
radiator fans
Condenser fan.
my wild guess to , engine over heats?????????
if yes, the scan it first. no not last FIRST.
it dont work like you think its not a 1988 Samurai.
sorry,
on modern cars, they got smarter, the engine goes
gee the PCM knows water temp why have a fan temp regulator.
hark , now it dont. (saves cash on useless parts)
but has a relay , (well until you have my car and the relay is now 100% electronic, called a huge transistor)
we've used this tech in industry for years, but car makers just learning how still.
i digress. but evolution and history helps diagnosis.
what is there?
Ill look for you, ive posted this 100s of times
the book is 4 bucks to see online. the real deal
lets look now.
XL-7 (the dash matters big time)
answering for , overheats engine, and fans on RAD dead.
(some are staged, PCM brains... now. and also chain ops based on if A/C is on or not) facts.
first I see 2 fans... ok.
the next page shows nice block diagram of the fan system
yup, NOT Simple.
ill post those words for you.
"The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans receive positive voltage from the cooling fan relays which receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed cooling fan relay which is fan 1 relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the series/parallel relay which is fan 2 relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM grounds the high speed fan relay, which is fan 3 relay, and the series/parallel relay, which is fan 2 relay through the high speed cooling fan relay control circuit. This energizes the series/parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the fan 2 fuse 1 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 16 km/h (10 mph). This is to prevent a fan from cycling ON and OFF excessively at idle.
end quote.
i bet you didnt scan it , like 99.9 % of all posters here dont.
DTC Descriptors
Diagnostic Fault Information
is the ECT showing overheat, yes no?
if yes, it must operate a fan or 2.
the book even covers all tests for fans dead, in a large truth table.
both the FSM and alldata.com have that, its no secret ,its published in 4 major places.
lets back up
if the engine coolant is low (no that side tank the engine and rad)
the ECT will lie. if that happens the fans may not come one
that is because the ECT is useless measuring air, for water.
that water must touch ECT for ECT to work.
this is FIRST
then scan the ECT does it show overheating, IT must if it IS overheating. fix that next if it lies to you,(IR gun in hand)
The system has staged fans.
i cant find the trip points in my crappyy online pages.
but is like 225f then 250f trips. is my guess...
about. if the engine over heats, check fuses first then scan it.
it will simply tell you why its bad.
eg, fan1 output dead.
or if you hot wire a fan and its dead, then it is.
(only on cars with non modulated fans,,hot wire them,else not.)
now the link to the 4 buck real book.
the non dash XL7 (my guess) you this pick yourself... cant see car.
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
this is how it really works
the ECU has software that decide trip points for fans.
hard coded, this is. based on how hot it is and if A/C is on not.
its way smarter than 1988 and better.
the DTC errors can see an open line, shorted to ground or stuck 12v.(runs all time error)
(tells you relay is good or not)
25839272-0kjd5huq4lpr130nt243wle5-3-0.jpg no scanner no joy , sorry, tis a fact.....
Aug 27, 2015 | 2007 Suzuki XL-7
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
Passat code P0480
P0480 VOLKSWAGEN - Cooling Fan 1 Control Circuit Malfunction
Possible causes- Fan control relay harness is open or shorted
- Fan control relay circuit poor electrical connection
- Fan cooling fan harness is open or shorted
- Fan cooling fan circuit poor electrical connection
- Faulty fan control relay
- Faulty cooling fan 1
- Faulty ECM (very unlikely)
Apr 11, 2012 | 2007 Volkswagen Passat Sedan
Diagnostic code for my 2007 saturn ion says p0480 cooling fan 1 control circuit malfunction. what does this mean.
WHAT IT MEANS YOUR FAN CONTROL RELAY CONTROL CIRCUIT IS OPEN OR SHORTED TO GROUND. FAN CONTROL RELAY CONTROL CIRCUIT IS SHORTED TO SYSTEM POWER. THE FAN CONTROL RELAY POWER CIRCUIT IS OPEN CHECK COOL FAN 1 FUSE. FAN CONTROL RELAY IS DAMAGED OR HAS FAILED. PCM HAS FAILED.I LISTED ALL POSSIBLE CAUSES TO CODE PO480.
Jul 05, 2011 | Saturn Ion Cars & Trucks
When should both coolant fans turn on? 2005 vw jetta
The fan may not be the problem. It could be a few things not turning the fan on. It is hard to say how much this is going to cost. The error code that you have P0480 is Cooling Fan 1 Control Circuit Malfunction. So some component in that circuit is causing the fan to not come on. I hope this helps you.
Aug 19, 2009 | 2005 Volkswagen Jetta
Check engine light error code 480
Chrysler has issued a TSB (#18-004-07)containing the fix for an inoperative cooling fan on 2005-06 Caravans and Town & Country vans with the 3.3L or 3.8L engines. The problem usually occurs after driving in heavy snow conditions where snow and ice form at the bottom of the fan shroud and block the fan blade. This condition also sets a P0480 code in the PCM. The fix requires a PCM reflash. If you have an inoperative cooling fan or a P0480 code, check the version label attached to the PCM. If a software update has not been performed since this TSB’s issue date of January 24, 2007, you should have the update performed before you start replacing any parts.
Dec 13, 2008 | 2005 Dodge Caravan
NRS OTC  2006 Domestic, Asian and OBDII Smart Cable Super Bundle Logo
1,994 people viewed this question
Top NRS Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a NRS Electrical Supply Expert? Answer questions, earn points and help others
