Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
I'm need the 66mm basket for the coffee filter holder for the FrancisFrancis X1 Espresso Machine (2004). Someone threw out the basket from the holder. HELP!
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
I need to buy the filter basket.
http://www.redmonkeycoffee.co.uk/cart/indexframe.html?http://www.redmonkeycoffee.co.uk/cart/X1-filterholder.html Here you go.
May 03, 2011 | FrancisFrancis! X1 Espresso Machine
I have a francis x1 coffee machine need a seal
Call 877-854-4141, which is Empire Fulfillment. If you are not sure if the part is exactly right, ask them to email you a diagram of the part.
Oct 12, 2009 | FrancisFrancis! X1 - Stainless Steel...
X1, aluminium: no water filtering through
It is possible that the coffee screen area is blocked, since the steam and hot water work? Try removing the screen and cleaning.
Aug 03, 2009 | FrancisFrancis! X1 Espresso Machine
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
Where do i get gaskets for FrancisFrancis X1?
The Francis Francis machines are owned by illy now - you can get parts from them - 1-877-469-4559
-Tha Mp3 Doctor
Nov 12, 2008 | FrancisFrancis! X1 Espresso Machine
Basket sticks - FrancisFrancis X1
I have the X1 and have this problem. I do two things - the first being (paradoxically) to tighten the handle a bit - that often frees the basket. If that doesn't work, I loosen the handle (to the point where it's quite loose) and then turn the pump on - that gives enough pressure to the basket to free it. So far, that's worked for me 100% of the time.
Good luck! -Greg
Nov 16, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
26 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
