Question about Toys
Chelino roll 'n' go portacot - Toys
A1 rotation from A0 roll
I could't understand the question exactly..I will try my level best, it may helps you..
T770 plotter having three media paths..
1. Sheet path
2. Roll 1
3. Roll 2..
After initializing, printer will ask to load the media, you have to specify the desired media selection ie sheet, Roll1, Roll2..
If U R selected roll one, message appears on screen "Open Roll 1 cover", you have to follow the message, once the paper is loaded in the path, printer has to detect the paper,it has to pull inside with the help of the roll feed motor..
In this case If UR selected Roll 1 on printer screen & inserted Roll 2 media, printer will runs Roll 1 motor, not roll 2 motor.. This problem U might be facing..
If my suggestion is not helping U, pl let me know exact problem what UR facing...
Apr 26, 2014 | HP DESIGNJET T770 Printer
Which automaker owns Rolls Royce Auto's
Rolls-Royce Motor Cars Limited was created as a wholly owned subsidiary of BMW AG in 1998 after BMW licensed the rights to the Rolls-Royce brand name and logo from Rolls-Royce PLC and acquired the rights to the Spirit of Ecstasy and Rolls-Royce grill shape trademarks from Volkswagen AG.
Feb 07, 2014 | 1991 Rolls Royce Rolls Royce Silver Spur
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How can I change the paper. I cannot find the correct slot to install the new paper roll
    Press down on the button located on the side of the terminal to unlatch the
    paper roll cover, then lift the cover up and back
    Remove any partial roll of paper in the printer tray by lifting up
    Loosen the glued leading edge of the paper or remove the protective strip
    from the new roll of paper. Unwind the paper roll past any glue residue.
    Hold the roll so the paper feeds from the bottom of the roll
    Drop the paper roll into the printer tray.
    Close the paper roll cover by gently pressing directly on the cover until it clicks
    shut, allowing a small amount of paper past the glue residue to extend outside
    the printer door.
    To prevent the paper roll cover from damaging the print roller, always gently press
    down on the printer dust cover to close it.
    g+ypssoexzf1qaaaabjru5erkjggg==
    Mar 18, 2011 | VeriFone Omni 3700
    I need a repair manual for a 1990 rolls royce silver spur2 i want to put ball joints and front end parts in my self
    the repair manuals for any rolls royce are sold only by rolls royce and are quite expensive. call albers rolls royce in zionsville, indiana (317)873-2360
    Dec 30, 2009 | 1991 Rolls Royce Rolls Royce Silver Spur
    I have a Eureka Altima and not sure how to change the belt?
    1) Use handle release to lower handle
    flat onto floor
    2) Remove 2 screws from the front side of
    brush roll cover
    3) Lift and remove brush roll cover .
    4) Remove brush roll and belt. Thread
    new belt around motor shaft and
    brush roll
    5) Insert left end of brush roll first. Make
    sure square on brush roll cap is in
    place. Pull right side of brush roll to
    stretch belt. Secure right end cap into
    base.
    6) Rotate brush roll 2 turns to center belt.
    7) Replace brush roll cover
    8) Replace 2 screws
    And you can get the maual here.
    http://www.eureka.com/service/manuals/80244.pdf
    Good luck
    Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
    Replacement paper roll size???
    Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
    Sep 26, 2009 | Sharp EL-1197PIII Calculator
    Wireless Dell mouse, wheel in middle, 2 buttons, black and silver.
    First try to reinstall the updated driver for your mouse. If this does not work, it could be that the mouse is worn out and you may need to replace it...
    Mar 21, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Toys Logo
    215 people viewed this question
    Top Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Toy Expert? Answer questions, earn points and help others
