Question about AEG L86800 Front Load Washer
Aeg washing machine fault code
C3 buzzer and pre-wash + main wash flashing lights
model Lavamat 86720
Please reply soonest,
thanks
e-mail, richardson560@hotmail.com
  • Anonymous Mar 13, 2009
    on my display says error C3. Could you please let me know what to do?
    Thank you in advance.
    Kind regards
    George N.
  • billie-jeanr Feb 23, 2010
    half way through a wahing itcome up with a fault code E20? Can you help
  • 3,230 Answers
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Posted on May 06, 2009
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
Hi my AEG OKO-LAVAMAT 88830 is about 10n years old. Today I was cleaning my machine. I filled the machine up with water on the rinse cycle then turned it to pump. I did this a few times as I have had a...
According to my list for AEG Lavamat washers, 'C3' stands for 3 possible causes 1 'safety flood device operated' (I suspect it means that it has sensed some water in the bottom tray. Not an easy job to do but I would check for a leak underneath), 2 'pump fault' and 3 'module fault'. Sorry I can not be of more help ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | AEG Lavamat 88840 Front Load Washer
My Washing machine Brand : AEG and model : 84740 update and problem is when switched on its showing error message C3. And blinking 3 light as well one is 1400 light , and other 2 is washing program
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jun 28, 2011 | AEG Washing Machines
My washing machine AEG lavamat 86800 (1998) blinks C9 and says no centrifuging and pre-wash. Thank you J.
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
Jan 17, 2011 | AEG Washing Machines
Fault c 9 is flashing on my oko lavamat 86720
I FOUND OUT THAT C9 WAS SOMETHING WRONG IN THE MOTOR. CHECKED OUT MOTOR AND FOUND THAT THE BRUSHES WERE WORN OUT AND I REPLACED THEM. I THOUGHT THAT WAS MY PROBLEM SOLVED BUT IT WAS NOT THE LIGHTS WERE STILL FLASHING AND C 9 STILL THERE. I PHONED A FRIEND WHO FIXES APPLIANCES.. HE TOLD ME WHAT TO DO TO CONFIGURE IT. LEAVE THE MACHINE OFF AND PRESS THE PRE WASH AND SOAKING BUTTONS TOGETHER AND SWITCH ON. ALL LIGHTS WILL COME ON AND AND MACHINE WILL WORK IT DID BUT YOU MIGHT HAVE TO DO IT A COUPLE OF TIMES.
Nov 06, 2008 | Washing Machines
AEG Lavamat 86720 washing machine fault code C3 with buzzer and pre-wash and main wash lights flashing
This means your water sensor has detected a leak. it will stop when the sensor is dry.
post further comment for more help......
May 05, 2008 | AEG L86800 Front Load Washer
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG L86800 Front Load Washer Logo
1,475 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
