Question about Dometic Rooftop RV Air Conditioner
Blow circuit breaker - Dometic Rooftop RV Air Conditioner
  • Mike Butler
    Mike Butler Aug 31, 2010
    Happen when just fan on, or only when you turn to cool? Lights dim, and moaning sound from AC when turned to cool, then circuit breaker goes?
  • Dometic Master
  • 43,501 Answers
You compressor had gone bad...replace it...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 31, 2010
Fuse blows as soon as you incert it into yhe ignition circuit on my C300H countax
You have a short somewhere and you need to trace the wiring. For your diagnosis, use "circuit breaker" fuse which will auto-trip/reset if there is a short or high amp draw. I even replaced some of my fuse with circuit breaker.
http://www.autozone.com/electrical-and-lighting/circuit-breaker?filterByKeyWord=breaker&fromString=search&newYmme=true
Mar 11, 2015 | Cars & Trucks
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
We had a power surge now when i plug my fridge in it blows my circuit breaker
The power surge might have damaged the wiring to the refrigerator. You can check this one with a megar. That is only if the circuit breaker blows off, ONLY when the unit is turned on. Else, the problem may be that current is flowing through the neutral. You can check it with a tester and if so, report it to the electricity board. Else, as a temporary measure, you can connect your unit, bypassing the circuit breaker. But in that case the circuit breaker will never blow off regarding any complaints to the unit and may result in a slight power wastage.
Jul 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
Computer/Motherboard Issues
buy a circuit protector for just ur computer and call a electrition
May 12, 2010 | Gateway 507GR PC Desktop
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
When compresser comes on blows electric breaker
the outlet that you have the dehudifier plugged into has too many items plugged in on the same circuit and when the compressors kicks in it draws more amperage than the breaker load can hold thus popping the breaker either remove some electrical apliances from that circuit load or plug in elsewhere
Sep 14, 2009 | Kenmore 54501 Dehumidifier
FRIDGE IS BLOWING THE CIRCUIT BREAKER
Most likely you have a bad or weak circuit breaker. Consult an electrician for breaker change out. Make sure that it isn't hooked up with a GFI plug. They will not work on a GFI.
Apr 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Dometic Rooftop RV Air Conditioner Logo
96 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
