Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Starts will not move forward or backv belt is broken how do you change it can i do it without removing the deck
  • 183 Answers
No, the deck will have to be removed. You will also need to remove the stacked pulleys from the crankshaft of the engine. There are 2 idler pulleys in the middle of the belt path that will also need to be loosened in order to get the belt around them. You will need to put the new belt around the rear (transmission) pulley first, then work your way forward. Make sure to get the belt installed completely against the pulleys and not around the belt guides, as this will destroy a new belt very quickly. The 2 middle pulleys will be spring loaded. Mount the belt around them, then take the belt to the front. It may be helpful to engage the parking brake, as this will hold the tension off of the middle pulleys while you put the belt on the upper pulley of the front pulley stack. Reinstall the front stacked pulleys and release the parking brake. Carefully inspect the entire belt path. The belt should be tight, but movable. It should also not be touching anything except the pulleys. If all looks well, fire it up and test drive. If that goes well, reinstall the deck. The whole job should take an hour or two.
Posted on Aug 31, 2010
Huskee 26 hourse power 54 inc deck/how do i change both drive belts on this tractor
The one on the deck you will have to remove the deck. Flip it upside down and replace. There will be an idler wheel with a spring on it that allows you to release tension as you put the new on. The drive belt comes from the front of the motor and loops underneath to the cutting deck. There will be a point on the deck that you can get a little wiggle room to move it forward to get the belt on.
May 01, 2016 | Garden
I have a cub cadet 1320hydro. 38 inch cut how do I
un hook front drag links from deck move tractor forward an inch or two , loop belt around pulleys , push tractor back and reinstall drag links , if belt on mover deck has broken , it's gonnabe easier to remove deck from under tractor , then take off foot guards on sides , using a 5/8 socket and b-bar move tensioner till you can slide off belt from one pulley , reverse to install new one
Oct 03, 2014 | Garden
While i was cutting my grass my tractor istop and backed up to cut some grass that i had missed i then put it to forward gear then my mower did`nt go forward. i removed my mowing deck and checked my belts...
sounds like you might either have the wrong size belt or its not routed correctly. if you provide the model number i can show you diagram and part number (size) of belt.
Jul 08, 2014 | Craftsman Garden
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
The PLAY function of my Cassette desk doesn't work anymore
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Aug 10, 2012 | Kenwood Audio Players & Recorders
John deere riding mower will not go forwards or backwards and was just mowing yard with it. it will start it will cut grass but will not move now help
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
Apr 22, 2012 | John Deere Garden
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
129 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
