Question about Weber GENESIS E-310
My BBQ is 1.5 yrs old. the temperature doen not pass 350-400. I refill the gas tang after 2-3 BBQs. I clean it once 5 mths ago. What can I do? thank you
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
Can you find manual for charbroil bbq? model # 466454706, serial # 0606230411? its about 4-5 yrs old.
You can get an Owners Manual by contacting Charbroil's Customer Service at 866-239-6777.
Apr 11, 2011 | Char-Broil CharBroil Master Flame Gas...
1.mazda 5 rear shocks leaking + new replacements lasting 3-4 months! 2.mazda 5 e/window controlsnot working properly!
What you doing with this vehicle driving over a mountain every day ?? if they keep leaking then remove them and drill a small hole about two and half centimetres from the top of the piston and then thread the hole and make a small bolt with a metal flat washer with a rubber one under that ,then refill shocker with oil and refit ,you may have to push the piston in to get the oil in though but not on every type ,anyway refit shockers ,then when vehicle statrs to bounce again just refill with oil in situ ,so you dont need to buy new ones all the time just refill them ,easy just like the good old cars 40 yrs ago .
Feb 12, 2011 | Mazda MAZDA5 Cars & Trucks
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
Need to find lpg jets for 6 burner aussie roaster bbq. (the australian barbeque company) Bbq roughly 6 years old.
BBQs Galore sell these in their DIY section (Aussie Roaster is no longer sold at BBQ Galore, but the burner component is a standard fit). If you have an Aussie Roaster remember there is a bobbypin on the underside of the burner locking the back end of the burner in place, a few smacks with a little hammer will push this out so the old burner can be pulled out and new burners can be put in place.
Oct 17, 2009 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Ice isn't forming, even though there is water to fridge.
Check the compressor if fridge is over 5 yrs old. If gas is low. You will need to refill it.
* Check the temperature setting
* Assure that there is enough room for air flow in the freezer or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condenser coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Aug 08, 2009 | Refrigerators
Weber GENESIS E-310 Logo
90 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
