Hi, I,m looking for the piezo wire for a Locke Home Products Warm Morning vented LP heater. Model VR50LBP. Thanks, Dave
  • shoebox622 Aug 31, 2010
    Thanks for the quick answer. Dave
  • 905 Answers
The piezo wire can be ordered from Stove Parts Unlimited. See Page 39 of the parts pdf file, under category Switches, Igniters, and Speed Controls. 2 lengths are featured.
www.stovepartsunlimited.com/
You might also be able to scrounge the wire from a bar-b-que pit piezo ignition repair kit, available at many of the larger retail stores.
Posted on Aug 31, 2010
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
Bought a used lp gas heater stove for living room.need istructions with pictures on how to install the vent. did not come with a manuel and unable to find info needed on website. this is an Empire Cast...
You have this posted under the Z-vent heading... is that the make pipe that came with the stove, and if not, what vent pipe came with the stove... we need to know which pipe it is exactly to be able to help you best...
heatman101
Aug 29, 2011 | Flex Z-flex Vent Pipe For Gas & Lp...
I have purchased a Procom ventless heater (ML250TPA) and need to know if I have to put a low pressurer reg. on the system outside or will this model heater reduce the propane pressurer coming from my 500...
This heater is designed to work with LP gas. You will need a regulator from the tank to the heater set at 11"wc .that's standard for any LP gas system. Your existing piping system should have a regulator already outside of your house before the gas inters your home .If it does not then you will have to install one. The regulator can be inside but you will have to run a vent line in copper from the regulators vent to the outside of your house.
Hope this helps ......
Nov 23, 2010 | Heating & Cooling
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Jandy Lite 2 LP 400 will not activate the ignitor. Power is on.
Somewhere on the panel or inside there shpuld be instructions telling what 4 flashs represent...
Could be a high limit that needs reset, a rollout switch the needs reset, or a pressure switch if you have a vent blower on that unit...
heatman101
Apr 24, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
Takes 4 ever to start up
Dave, Please, stop turning your heater on and holding your unit up to the vent. This error is not a unique one, but it is one that requires parts to be replaced. The keypad board has 2 wires coming off of it and they sit right ontop of your LCD. More then likely that is what will be replaced. The only problem is, is that you can't buy individual parts from Magellan. So, ATC Logistics & Electronics (Magellan repair center) in Fort Worth, Tx would be your next move if your wanting to pay for repairs.. or just get a new one. -Daniel
Aug 04, 2007 | Magellan RoadMate 700 GPS Receiver
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
