I am looking for the top cover panel for a KSA 150, any ideas
  • 979 Answers
Hello Max, Hi, have a look at local electronics repair shops if they have one, IF no luck, go to a Car body repair shop and ask to fabricate one for you. the exhaust panel can be replaced by several bore holes from a drill, ask if they can also place an exhaust fan if you want to.
Posted on Aug 30, 2010
Service centre in Dammam KSA
http://www.bing.com/search?q=Dammam+KSA+pc+repair&qs=n&form=QBRE&pq=dammam+ksa+pc+repair&sc=0-12&sp=-1&sk=&cvid=24e46eba47994ac8b0bc0e6ce59d678a Dammam KSA pc repair Bing
Apr 06, 2015 | Computers & Internet
Monitor19" Belinea, after 10, 30, ...150 min turn
thake the back cover off. look in the power supply. there should be cappasetors which need replacment
Oct 10, 2011 | Samsung SyncMaster 710N 17 in. Flat Panel...
Ptv home show secrambeld i want open on asia satilite in ksa
ptv h
ome ptv sport ptv news ksa main phaly asai set per tha ab pta nhi kdr chala gya pls kuch krn
May 15, 2011 | Televison & Video
Power mirrows will not work on 2005 F 150. What could be the problem.
Have you checked your fuse? If not you can look in the fuse box located under the right-hand side of the instrument panel. Remove the trim panel and fuse box cover to access the fuses. The fuse you are looking for is a 5 amp fuse and is in the number 3 position in the box (along the bottom row see diagram below). This fuse also covers the memory seats & pedals. This may be your problem but there may have been a reason it blew if it did blow and then you are looking and more work into the reason it is blowing if it continues to blow. I hope this helped and good luck.
Mar 01, 2011 | 2005 Ford F-150
Where do I find the fuse box on my 2006 F-150?
The owners manual is not real clear on this, it is in the passenger side kick panel, by the fuel inertia switch.
If you lay on the passenger floor looking at the kick panel, you will see a thumb hole. Pull this, the panel is hinged like a door with 2 plastic tabs. Switch in in towards the center of the truck in an arc towards the back of the truck.
Behind the kick panel is the fuse panel ( with the fuse panel cover on it ) and the fuel inertia switch.
May 14, 2010 | 2006 Ford F-150
I have a 2000 Ford F 150, blinkers are not working
OK! Thank you Lord Jesus. I just fixed mine. This problem is most likeley the caused by trucks with tilt stearing. The harness is to shourt on some trucks and when the wheel is in the down position it will pull the plug on the harness that runs the blinkers. My emergency flashers worked if the wheel was in the up position. When I put it all the way down, they no longer work. First remove the tilt leaver by turning it counter clock wise. If it is to tight the is a small indent on it the you can use an small adjustable wrench on. Then remove three philips screws from the lower stearing wheel shaft cover. After the lower cover is removed pull the upper one up slightley and you will see many connections. The fist one to look for is very large top center. Mine was half way disconected. I pushed it back together but this did not fix my problem, but make shure yours is setted all the way just to make sure. Now look at the connection coming out the back of the turn signal. Mine was loose here also and when I pushed it together all the way my problem was solved.
Hope this keeps everyone else from getting hit or paying a big repair bill.
Kapptain-K
Dec 27, 2008 | 2005 Ford F-150
F-150 whip style truck antenna
The cover just pops off. I like using a door panel tool and get under the lip of the cover and pop it off.
Jul 01, 2008 | 2003 Ford F150 Regular Cab
Taking cover off dryer
open door and look for screws going up into top
Jan 04, 2008 | Dryers
21 people viewed this question
 Grubhead
Grubhead
