I have a Sony DAVHDX975WF Home theater system, the dvd tray wont eject I get a please wait message followed by error code C 3100 All tray lights are on but there are no disc's in the system
sandrew
  • 2961 Answers
SOURCE: Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Posted on Apr 18, 2007
SOURCE: PL-D2000 DVD Home theater System
Turn on the player for about an hour untill it heats up and then play the disc. Most probably it will work. If not you will have to replace the lens or card.
Posted on Dec 30, 2007
SOURCE: Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
Posted on Jan 22, 2008
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
ginko
  • 19396 Answers
SOURCE: protector push power - dvd home theater system
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Dvd disk try wont come out
There is a small hole on the front of DVD near buttons... Straighten paper clip and insert into hole, a gentle push should release tray so you can open and remove disk..Sounds like you did not seat DVD properly
May 29, 2014 | Sony DAV-DX250 System
I would like to make my player region free
there is a way to make your player region free - do the following:
I have a new HT-E3500 and did the following:
I have a Region B/4, player
I used the R4 code from below.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
It needs to be done without delay. (consequently)
So if you don't get it to work straight away don't loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Nov 12, 2012 | Samsung HT-E3500 3D Blu-Ray Home Theater...
How do i change my region on my samsung HT-E3500 i am in mexico and can't view my dvds from the states
tengo la misma pregunta , lo he comprado en el palacio de hierro y no pudieron hacerlo multiregion , lo llevare a un centro de atencion a clientes , si se algo te paso el codigo o, o si tu lo sabes antes me lo pasas . Saludos
Nov 10, 2012 | Samsung HT-E3500 3D Blu-Ray Home Theater...
Samsung HT-E3500 region-free
I have a new HT-E3500, and after 20 minutes I got the following to work.
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running 080604.01_050708-1_XSA code.
Now it to me about 20 tries to get this to work, It needed to be done without delay.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jul 02, 2012 | Samsung HT-E3500 - Home theater system -...
I have sony mini hi-fi mhc-gnz88d now it's displaying DEST ERROR and can't open disk tray or run a CD. how to solve this?
i hv also this problem from yestrday.. all function are ok. bt when playing dvd ... there is 'please wait'error long time. and also tray not open after pressing open or exchange cd also... whats problem.. please help me.. waiting
Dec 25, 2010 | Sony Televison & Video
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
BEST ERROR
You right, it calls "DESTination ERROR". You need to replace an IC in DVD Processor Board. If you technicalities of IC replacement, IC can be provided on charge basis.
Jul 27, 2008 | Sony Dream System DAVDX155 Theater System
73 people viewed this question
 Grubhead
Grubhead
