Question about Oreck XL Ultra Bagged Upright Vacuum
Replace belt on my oreck xl
How do i replace the belt on my oreck xl vacuul cleaner?
  • 1 more comment
  • Anonymous Mar 15, 2014
    How do you install docking system on oreck xl upright
  • Anonymous Mar 24, 2014
    pushes hard
  • Anonymous Mar 29, 2014
    remove outer bag
    President:
  • 1,673 Answers
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
Just replaced the roller on my oreck XL, and it is smelling like burnt rubber
If the roller bearings are starting to seize the the belt may be slipping
Oct 25, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Replacement belt Oreck UPR014T XL
Ok its sounds like you need a new brush roller and change your belt
Aug 13, 2012 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
My oreck XL7 smells when it's on. Smells as if it's the motor. Had the Oreck for 4 years but hardly used it?
The smell is probably from the belt. When they are worn and stretched they can start to smell. You can get replacement belts for your model here:
Oreck XL7 Replacement Belts
Nov 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Oct 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
May 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I am not sure how o install a new belt on my oreck vacumm, can't
here is the insturctions (copy and paste in your address bar)
http://www.oreck.com/vacuum-cleaner-bags-and-belts/index.cfm?keycode=DB475
Feb 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck 9100C Vac
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=647356
Oreck 9100C Vac
Posted by thecleaner on Jun 04, 2008
How to I replace both belt and brush correctly.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL 9100C Ultra Bagged Upright Vacuum. The best way to install the belt is to put the belt on the brushroll 1st and then install the brushroll, the brushroll has marking on the top and the bottom of the bearings stating NEW or USED / OLD and install them identical on both sides and then use a belt puller to stretch it onto the motor pulley. The best place to get instructions on how to install the belt and brushroll is the owner’s manual and an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
414 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
