Question about E-Machines eMachines Desktop PC
No ethernet drive since system restore - E-Machines eMachines Desktop PC
  • 808 Answers
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner and then install ur recommended driver as u want to install ethernet driver
Posted on Sep 01, 2010
System Restore Disk won't work
The Recovery disk could be damaged or corrupted. The reason you are getting the Ethernet controller error your laptop can not find an operating system on the drive. With the aspire try ALT-F10 when you power on the system it will take you to a system restore partition. This will only work if the Hard drive is working. And it will wipe your drive so if you did not have any backups well you will lose all data on the disk.
Apr 27, 2013 | Acer Aspire Computers & Internet
Error message "restore failed 0x00000070"
Step 1:
Which operating system ?
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings. Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard, mouse or monitor. Click the Windows "Start" menu and choose "All Programs." Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab. Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default." Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process. Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
Mar 10, 2013 | Computers & Internet
I cant connect to my internet using a ethernet cable, it say limited or no connection yet after going through this with virgin media for an hour turns out the problem is to do with me not them, please
if you were able to connect earlier on this computer and if you can connect on another system/ computer using the same ethernet cable and virgin media connection as of now it does mean that the issue is computer specific so you can try a system restore thru start>>programs>>accessories>>system tools>> system restore and restore the system to a earlier time when you were sure that internet connection worked. you can also try forcing ip and dns settings which Virgin media can provide. also you can try changing the speed and duplex settings to force 10mb half duplex and see if it works. Good luck
Feb 07, 2012 | Microsoft Windows XP Home for PC
Network card disappeared overnite
Before adding any ethernet card, try to restore your system by using system restore option available with windows to a date on which your system was perfectly working. If the your system works fine after that, then it is quite likely to have your system infected by malicious software or anti virus. Scan your system for virus. If the ethernet is not working then add a new card after disabling the on-board network card in the CMOS setup.
Jan 01, 2012 | Dell OptiPlex GX620 PC Desktop
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My ethernet drive,my sound drive and my PCI drive doesn´t work.....please gave me assistance
You can reinstall the sound, ehternet drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Realtek and install it and then select Ethernet and install it.
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System installed on your computer
Click Drivers
Select Audio (Realtek) and download it.
Once downloaded, install it on your computer.
Thanks and regards,
Jitha
Aug 30, 2010 | Acer Aspire 5610-4648 Notebook
Wireless will not work in my panasonic cf50 after running restore
You need to download the driver in order to get it to work. Suggestions are using the ethernet connection if possible, or by whatever other means you used to post this message and download the driver for the wireless network card. If you used a secondary computer to download the driver, use a jump-drive/pen drive/thumb drive/memory card/etc, to transfer to this computer.
Jan 10, 2010 | Panasonic Toughbook 50 Notebook
Acer Aspire x1300 Desktop/Vista. Ethernet Controller Driv
First thing to try, is to do a system restore. You can go back to an earlier time. Pick the lastest time right before you installed the updates. System restore should be found in the Control Panel.
Dec 27, 2009 | Acer Aspire X1300 (PV.SCC0X.002) PC...
Cant install the ethernet of compaq n610c
If the laptop is newer than 2001, it won't have a ROMPAQ on the hard drive. That was compaq's system BIOS that had to be installed on the hard drive.
If you go into the system BIOS, make sure that the ethernet is enabled.
If it is, then load into Windows and check the device manager to make sure it is there. If it isn't, a simple fix is to do a system restore to the date it worked.
In windows XP, it's c:\windows\system32\restore\rstrui.exe
In windows vista, it's c:\windows\system32\rstrui.exe
Aug 08, 2009 | Compaq Evo Notebook N610c
Reloading software, Hard drive replacment
i hope u re install your operating system,
after the re installation u did not install the drivers that is the reson, best way u buy an ethernet card and try to get net connection and down load the drivers from dell.com ,then remove the card ,thats it.
Jan 15, 2008 | Dell Dimension 4600 PC Desktop
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
