Question about HP Computers & Internet
VS17 Monitor - power light only blinks, but monitor screen stays dark.
  • 11,361 Answers
Look for bad caps in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Also read here: http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
Posted on Aug 31, 2010
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
Jul 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Screen does not go on.
You may have backlight inverter circuits failure or power supply failure, look inside for bad capacitors in the power supply first since it is easy to do, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps, inverter, or lamps: http://s807.photobucket.com/home/budm/allalbums
Mar 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hp vs17 monitor is glitching
Look for bad caps with bulging tops in the power supply section. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor power light is blinking. The screen is blank.
Hopefully it will go away if you can re-install your video driver. I guess it depends on how fast it blinks. These monitors are not easy to fix. Try and connect to different computer. Let's hope you can reinstall the driver and not have to service monitor.
Oct 24, 2009 | HP Vs17 17" LCD Flat Panel Monitor
My monitor will is black when booting up my computer. The keyboard light will come on and the light on the monitor will come on but then the monitor light on the monitor light itself will just blink only....
Disconnect the Cable that connects the monitor to the computer> from the computer> if u have an error on the monitor screen like No video signal> if u have some error then the monitor is fine> u need to reseat the RAM and the CMOS battery on the motherboard of ur computer>
if there is no error msg ur Monitor is bad> i hope it will resolve ur issue
Oct 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
Jun 23, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
