Question about Kenmore 24032\24036 Top Load Washer
My Washing Machine Drains out water immediately when water is filled into it. Its a Samsung Washing Machine triflow sw65ASP2.
  • Kenmore Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Aug 31, 2010
Why does my samsung washing machine only fill water for a couple seconds and then stops?
SAMSUNG CUSTOMER SUPPORT PHONE NUMBER:
1-800-726-7684
M-F
9-9 EST
Nov 14, 2014 | Washing Machines
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
My samsung triflow sw65asp2, the cold water is taking forever to fill the drum, the hot water seems fine. any idea what could be causing this?
(pre-typed for both hot and cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 25, 2011 | Washing Machines
I have a Samsung Washing Machine Intellect SW65ASP2 The error code is E. Filled with water and not draining. I undid a hose at the back and removed a coin which I thought was causing the problem. Any...
you should check the impeller, the thing that looks like a fan, when the coin got in there it would have popped the impeller of the shaft, it does this to avoid burning out the motor. it just pushes on
Jan 29, 2011 | Washing Machines
Samsung SW65ASP2 top load washing machine only lets water in slowly.
there may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Jan 31, 2010 | Samsung SW62ASP Top Load Washer
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Hi I have a Samsund Washing Machine SW65ASP2 triflow and i put a load on and it went find. Went to do another load and it came up with Code DE
DE is a door lock error it could be the door hasn't been shut firm enough or the door lock may have failed. Sometimes the pin that goes through the handle and ****** comes lose the door would have to be taken apart to check for that and in some rare cases the main module can be faulty.
Dec 20, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
254 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
