Question about Cub Cadet 46" Lawnmower Deck Drive Belt 754 04153
Deck drive belt keeps coming off and/of breaking after mowing for 5 to 10 minutes.
  • hahnfamily Aug 31, 2010
    I got a new belt and put it on accordding to the diagram. It broke after 10 minutes of use.
  • mikeProllins May 30, 2012
    The Cub Cadet mowers are notorious for poorly designed belt-deck configurations. The Idler Pulley Brackets are inadequately supported with springs leading to excessive vibration combined with a misalignment of the pulleys will lead to eventually the belt popping off of the deck and/or being cut by the pulleys themselves. Solution to this problem for the LT1045 and other similar models can be viewed at:http://www.youtube.com/watch?v=Pd4nYovcn...
  • 503 Answers
You either have a bad or loose pulley, a stretched belt or a tensioner that isn't working right.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Aug 31, 2010
  • Monika Arora
    Monika Arora Aug 31, 2010
    OR
    You can try this...
    There are a variety of reasons why a mower belt may come off. Below are some basic steps that may be of assistance. As always, you can contact your local John Deere dealer for assistance.
    Before doing any checks, be sure the engine is off. Remove the key to prevent accidental starting.
    The first thing to check is the mower mounting system. Raise the deck to its number 4 position. If there are any parts missing the deck will not hang evenly. Look at the rear hangers and make sure the clip pins are in place on both sides. Verify that the front draft rod that connects the front of the mower to the tractor’s front axle is connected.
    Next, look at the condition of the entire mower belt. Remove the belt, if it isn’t already off. See your Operator's Manual for help with belt removal. If the belt is badly frayed, or there are sections of the V missing, the belt will have to be replaced.
    Now look at the drive pulleys. It will be necessary to remove the plastic cover to get to the pulley on the left side spindle. Check for foreign objects, like sticks or acorns, stuck in the V. Look for bent or distorted pulley edges. Damaged pulleys will have to be replaced to ensure good belt life.
    Check the idler pulleys. Idler pulleys have a ball bearing in the center. The bearing should turn smoothly. A small amount of play in the bearings is acceptable. You should be just barely feeling a slight movement, if there is any play at all. Excessive play indicates replacement is necessary.
    Find the movable idler arm on the top of the mower deck. On the 42-inch deck, it is connected to the blade engagement cable. The 48-inch deck has a large spring connected to the arm. Check for grass clippings or other foreign material under or behind the arm that may be limiting its travel. Move the arm by hand. The arm should pivot freely against the spring tension. If the arm seems stuck, try spraying the pivot point with a spray lubricant and try moving the arm again. If the arm still doesn’t move, remove the bolt and nut holding the arm to the deck and sand off any rust found on the pivot bolt and the inside of the idler arm with fine sandpaper.
    Now check the mower blade spindles. The 42-inch deck has a brake system that locks the spindles when the PTO lever is in the off position. If you have a 42-inch deck, turn the PTO lever on for this next check. With the belt still off, turn each of the blade spindle pulleys by hand. They should turn smoothly. Then grab the nut on the top of the shaft and try to move the shaft left or right to check for bearing play. You shouldn’t be able to feel any play in the shaft. If the shaft wiggles, see your John Deere dealer for service.
    Finally, measure the pitch or rake of the mower deck. The deck is designed so it cuts best with the blades 1/8 inch to 1/4 inch lower in the front than in the rear. This is sometimes called pitch or rake and is measured at the tips of the blades with the blades pointed straight forward. Excessive rake can cause misalignment of the belt and make the belt come off. See your Operator’s Manual for deck leveling procedures.
    Brigadier General:
  • 3,513 Answers
The reason why its comming out is because it become bigger in size and gets loose and comes out. Please get a new one and replace it as mentioned in the bellow article:
http://www.ehow.com/how_6382509_install-model2186-mower-deck-belt.html
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 30, 2010
Why does the deck drive belt on a cub cadet 2042 keep coming off and or breaking every time you try mowing the yard ?
My first guess is the belt is not properly routed through all the pulleys and past the belt keepers. Please check everything twice against the belt diagram in your operator's manual.
Mar 02, 2017 | Cub Cadet Garden
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Need diagram for a poulan xt 30" belt route on deck .Belt keeps breaking shortly after changing I am beginning to think that all the gumballs from the gum trees may breaking it is that possible
Two things first if it just keep breaking..the most probable cause would be the belt on one the spindle or drive pulley " on engine " is routed around most of the pulley then over the belt keeper instead of on the pulley grove..or the keepers are way out of adjustment the keepers have sharp edges on the outside and will tear up a belt in no time...as for the routing most are simple and follow the same procedure,,first look at all the pulleys on the mower deck...there are two kinds the drive and idlers..the drivers are attached to the engine and spindle where the blades and have deep v shape and have on or two belt keepers attached very close on the deck..the others are idlers including the tensioner that engages the belt and keep tension,,they do not have v they are flat with two small right angle edges to keep the belt straight they are designed to ride on the flat back side of the pulley..first detirmine the rotation of the pulleys the starting at the engine drive pulley place the belt in and follow to the first pulley in the direction of mowing all the way around the then operate the engage/disengage lever it will move the engage idler pulley..fit the belt on the flat side the locate others and do the same..you will need to play with it awile but you will find the route...just remember when you do route it look for and adjust the belt keepers..they are there to keep the belt on when running disengaged...you know the results once off the pulley a torn up belt...this is long but i believe if you take your time it will help...good luck.
Mar 20, 2016 | Poulan Garden
How can i keep my deck belt from coming off every 5 minutes
Hi there Anthony,
Lower the deck to its lowest position and have a look underneath between the mowing deck and the chassis.
Many ride-ons (even John Deeres!) have the pulley angle set so it is perfect with the deck up at its maximum height (where no-one mows except maybe the one man and his dog) but down at normal mowing level the belt leaves the deck at a much steeper angle, causing it to wear much more quickly, or even jump off the pulley, being stretched against the top lip of the pulley.
I recently fixed the our John Deere with this same problem by taking a medium adjustable spanner and (carefully) bending the offending deck pulley's steel strut (using a larger spanner to turn the handle of the smaller spanner) to enable the belt to leave the pulley at the correct angle. Our belt life more than doubled after this.
While you're under there, get a torch and check out the belt tensioner pulley(s) as well. Some ride-ons have the tensioner on the deck, others up under the chassis. Follow the belt up till it hits the underside of the chassis and you'll normally see a pivoting pulley that keeps the belt tight, no matter what height the deck is.
These pivot on a bush that can get badly slogged out. Release the tension from the belt and check the up and down play of the pivot.
Sometimes these pulleys get so badly worn that there is no lip left to hold the belt any more.
May 26, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 HP Lawn Tractor PTO will not engage
did you break the deck belt?did you over load the electric clutch and blow the fuse?
Aug 06, 2012 | Garden
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Bilt that runs off of main drive pulley keep, to deck comes off
If you have an owners manual, verify correct routing of the belt. If this is correct, check all the pulleys with the belt off to ensure they turn freely. Recommend not mowing with the deck in a very low position also. This creates an awkward alingment. Let me know.
May 19, 2009 | Garden
Cub Cadet 46" Lawnmower Deck Drive Belt 754 04153 Logo
526 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
