Question about Radio Shack VGA PC Camera Webcam
Is there a microphone on this product? If there is, mine isn't working. How can i get it to pick up on audio?
  • 2,885 Answers
Check out the audio settings on your computer to see if it can detect a mic
XP
Plug in your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
Plug in your webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Posted on Aug 31, 2010
Philips SHG7980 microphone problem
Go to Tools...Options...Audio Settings and try choosing different choices for Microphone.
Jan 18, 2014 | Philips PC GAMING HEADSET BLACK/RED...
MY SE X1 MICROPHONE HAS LOW INPUT ON MY FOCUSRITE PLATINUM VOICE PRO PREAMP
Have you tried a different pre-amp to narrow down the possible issues on your audio chain? Or ensure your preamp works properly by trying a different mic on it..
Also, if this is a stereo setup, try balanced cables to ensure this isn't a phase issue - which can reduce volume dramatically.
there are some programs out there that can boost audio, but if the mic itself is damaged, then take it to an electronics/mic expert.
Apr 12, 2012 | SE Electronics SE X1 Microphone
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
My microphone device isn't working to record and the sound always stops
im not sure what isn't means
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Apr 16, 2011 | Dell Computers & Internet
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
My pc is not picking up my mic from the mic slot?
Control Panel/Sounds and Audio Devices/Volume/Advanced/Playcontrol/Options/Properties/Playback ( check microphone )/Recording ( check microphone) set your volumes. Also make sure your devices are set in the Audio tab.
Aug 02, 2009 | Audio Players & Recorders
Microphone
It really depends on where you will be using the microphone and and whether it is just going to be used for fun at home or in a club oor for recording?
Some golden rules for microphone selection.
1) Make sure the microphone is Uni-Directional. This means it will only pick up sound from the direction it points in. You are less likely to get feedback or background intereference.
2) For a vocalist, make sure the mic is a reasonable size. If it is too small and you need to hold it, after a while it becomes fiddly and uncomfortable.
3) When singing always use a foam hood or pop filter with the microphone. This will reduce explosive sounds on the letter "P" etc.
4) Choose a microphone with a wide frequency response but not too much bass which can make vocals sound boomy.
5) Finally, the microphone must have a reasonable dynamic range so that if you suddenly shout it does not distort excessively, but it will also work when you speak or sing softly.
Feb 29, 2008 | Audio Technica Audio-Technica ATW-T341...
When I record using my microphone I hear "pops" and 'hissing" when listening to the playback. What can I do to prevent this? The moment I plug in an external mic (a Sennheiser) a low level rumble starts...
These mini video cameras are great for a lot of reasons, but the drawback is the tiny buttons and connectors, like the microphone input. It's probably actually a stereo microphone input.
If it is stereo (check the manual), then try using a stereo adapter, where you plug the adapter into the stereo mic input on the camera, and then plug the single microphone into only one side of the adapter ... then copy the audio to the "missing" side later in production ...
Alternative: record the audio separately onto a decent quality audio recorder with proper microphone jacks, then find the corresponding audio and synchronize it in software production. This is often how professionals do it, and one of the reasons you see the familiar "clapboard" snap at the beginning of movie shoots ... clapping your hands on camera right before you shoot will give you a visible action that will correspond to a peak in the audio soundwave that you can match up to synchronize the audio once you put the video and audio into your computer.
Another alternative - new item these days is an audio interface for video cameras that is basically a small black box that mounts onto the video camera or tripod, plugging into the tiny input on the camera and providing XLR microphone inputs ... just go to Borders and pick up any magazine on video production, you'll see them advertised all over the place ...
Good luck, hope I have helped in some way!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Dec 18, 2007 | Sony Handycam HDR-SR1 HD Camcorder
Radio Shack VGA PC Camera Webcam Logo
102 people viewed this question
Top Radio Shack Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
