Question about Kenmore 43142 Front Load Washer
Kenmore F/L Washer Model 41743142200 tub loose
The tub on my Kenmore F/L Washer Model #41743142200 is very loose. It rotates fine whether spinning slow, fast, counterclockwise or clockwise but about 4 times during the cycle, it makes a really big banging noise ‘cuh clunk, cuh clunk’ for a few seconds. The banging seems to happen after some water drains and it starts to go counter clockwise.
  • A5555 May 30, 2008
    It was a shock that was broken and since then we ordered and installed the replacement part and my washer is working better than ever. Thank you!!!!!
  • terronez1 Oct 17, 2008
    Same type problem but the tub makes a noise any time it is rotating.
    Genius:
  • 1,073 Answers
You may have a dampening shock that is bad
Posted on May 08, 2008
Washer will not spin. it will fill then immediatly empty,3 time no spin or wash. belt is on, motor spins freely, the timer does move with cycle but fast kenmore 41743142200
this sounds like a timer problem, but need the make and model number to be sure, this model number will be on a on the rear panel of washer, or with the original owners manual.
Aug 17, 2010 | Washing Machines
KENMORE, Model # 41743142200 gets stuck in mid cycle. It keeps pouring water into the washer and right out the drain. (Slowly) It will sit on the cycle as long as you let it.(Timer not moving) Never...
You may have a drain hose cyphoning out the water. Make sure you have a air gap in the drain between the hose and the drain pipe and make sure the drain hose is higher than the tub of the washer. If this is clear you may have one of the following. Either a bad water level switch or a bad inlet valve. To find out if the water valve is bad while the water is pouring in unplug the machine and see if the water stops. If the water stops the valve is fine. If the water continues to flow you will need a new valve. If the water stops then you will need a water level switch. Let me know what happens and I will be happy to help.
Michael Anderson Owner Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Washing Machines
Replacing shocks on front load washer
through the lower door panel in front of machine. Why???? is machine walking , bouncing or other wise?? This machine spins at HIGH Rpm's so most usual problem is one leg maybe unlevel or possible wood floor maybe "giving " as machine spins and allowing the machine to walk...but then again if machine is "old" shocks could be worn out
May 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Spinning problem
Following your description the problem is with the lid switch. Get an access to it and find out whether something prevents his smooth movment,its has a loose wire connection or the switch is malfunction and should be replaced. Good luck!
Sep 04, 2007 | Kenmore 22422 Top Load Washer
Kenmore 42990 front loading washer
If this is a 417 model your problem might be the pump itself. There is a pressure switch that detects whether or not there is any water left in the tub. If so, it will not go into high spin. Remove the lower panel and check the pump on the lower right side. See if there is any gunk or coins in there by removing the hoses attached to it. Have a flat pan or a bunch of towells ready to catch the remaining water from the tub. If the pump checks ok, the next move would be to check the motor controller itself.
Apr 25, 2006 | Kenmore 44921 Front Load Washer
Kenmore 43142 Front Load Washer Logo
867 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
