Question about Samsung Washing Machines
SamSung SW51ASP 5kg keeps saying de and beeping as if it was un balanced but its not
2 Suggested Answers
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Posted on Oct 03, 2009
Am nevoie de un cod sa decodez un samsung corby daca e nevoie trimit si imei_ul
Pute?i ob?ine codul de deblocare prin intermediul on-line .......... da numarul tau de IMEI ?i a ob?ine codul de deblocare pentru telefoane mobile ur .... i se va sugera site-ul web Deblocare-Zone.com, care este de a face un serviciu bun ..... pute?i abordare acest site.
Acest site este aproape perfect? ?i au fost extrem de recomandat ?n forumuri telefon mobil. Le-am folosit pentru a debloca telefonul meu mobil. contactat-le ?i ?n termen de 30 de minute am avut codul de deblocare ?i telefonul meu a fost deblocat.
Sper c? acest lucru ajut?.
Aug 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Quiero gravar musica para una memory card sd y no se como acerlo
Deberás de grabar através de la entrada de línea de un ordenador, la clavija de audio de color rosa. Con eso y un programa de grabación de audio, audacity por ejemplo: http://audacity.sourceforge.net/download/windows . Luego guardas el archivo a un .mp3 y lo copias/pegas en la SD.
SAludos!
Dec 06, 2010 | Samsung Mac Notebook
Hola me sale un cartel que dice dns NO disponible continuamente en mi celular, samsung b3410
hola yo tengo un celulat gt-b3410 y cada tanto me pone unos carteles de usuario y contraseña no validos y otro cartel de error de DNS y demas carteles, quisiera saber como como hago para poder arreglarlo muchas grax
Sep 27, 2010 | Samsung B3410 Cell Phone
Plano tv samsung txe2746
saludos tengo un problema en la fuente de alimentacion y exploto el integrado que esta unido a un disipador de calor precisamente en el serial del integrado quien me podria ayudar facilitando el plano electrico del samsung txe2746.
gracias
Jan 07, 2010 | Samsung TXE2746 27" TV
No network coverage
j'ai gros problème depuis 1er sept , date de changement de plan orange avec mon iphone (0679186016): pas de connection x 1 sem
impossible de parler à un technicien sur no recommandés par internet : que des répondeurs : as-tu un no de service orange portable à 10 chiffres ou je puisse parler à qqun avant mon départ mardi ???????
merci ++++++++++++ d'avance
F Sestier 1-514-912-4436
Sep 07, 2008 | Samsung SGH-T519 Cellular Phone
NCR 7875 SCANNER/SCALE
Hello
Well regarding this error sending you this display of the scanner in most cases is needed because if the scanner calibration, you have to do is:
Remove the dish from scanner (where you put the products to weigh), there you will see that has a plastic part on the right side, and take away that the bottom is a black button color you need to start to put pressure gauge.
Once you press this button, and is ready to start calibrating, then put him back to the plate and the scanner with a voice that sends you will be asking some weight, so this should have on hand your weights to calibrate the scale.
First the scanner asks 0 kg. in this step not going to put anything in weight, ahi press the button Scale Zero appearing in the panel's scanner,
After asks you to 2.5 kg, is there when you need to put the 2.5 kg asks you, when you have them placed on the plate press Scale Zero, the scanner then will ask now that you put 5kg, then you take away those who had 2.5kg and you put the 5kg, and when you have 5kg in the dish press the button Scale Zero, now the scanner will ask that you put 10k, then take away the 5kg and that he had put the 10k that asks you to press the button and Scale Zero, and finally asks you to the scanner in this 0Kg, then you take away the 10k and leave it with nothing, and press Scale Zero
If the calibration did well Scanner you send a voice message that says Calibration Complet or calbración completed, it is very important that when you calibrating the scanner is not moving or having obstacles that may make the calibration is not made well, good clean plate and that this part of the bottom, which revises the 4 Gomito that has to sustain the plate are complete, that are not broken up or are some more than others and that when you put the dish did not move. fijate also not hit the plate or the chassis of the scanner with something else, so there's no obstacles in the calibration,
If you salio calibration is not well in the display will show a 9Error, this means that there was interference during calibration, it is required to check well before the scanner or do a cleanup.
Feb 21, 2008 | NCR 7875
Samsung sw51asp top loader washing machine
Nov 06, 2007 | Washing Machines
Video controller driver problems ...i guess
Let's backup a minute. What Version of Windows are you running?
Jul 02, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Washing Machines Logo
117 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
