Question about Jacuzzi Pool & Spa
We have a 1hp pool pump for 35k gallon inground pool, recently the pump has become increasingly louder , the noise sounds like the pump is laboring and lost prime although the water flow is good and consistent as usual. Is this a sign of the motor going or the pump mechanism? Is it worth fixing or should it be replaced
    President:
  • Jacuzzi Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 31, 2010
Pool pump turns on, starts clicking then turns off
It appears that the motor is overheating, and then it turns off. There is a thermal overload switch that will turn off the heater, and when it cools back down, the motor will turn back on.
A few things to check:
  • Debris in the impeller
    • If so, remove it, this is causing the motor to overwork
  • Was motor / impeller recently changed?
    • if motor was downsized from the one prior, it is overworking, because the impeller is still sized larger.
    • if impeller was upsized with an undersized motor, the motor is overworking
  • Is the motor louder than normal?
    • The bearings are probably failing and the creating the motor to labor.
Good luck
Mar 11, 2015 | Sta Rite Sta - Rite 1hp Dura - Glas...
What is gpm flow for this pump
for the 1hp size this pump is capable of generating 76 gpm at 0 feet of head pressure of course it goes down from there as you increase head pressure (lift)
May 28, 2014 | Pentair Pinnacle High Performance 1 HP...
Pinnacle high performance one hp have a reset button
if humming and not running bad start up capacitor or bad motor replace pump be safe
Apr 20, 2012 | Pentair 1HP Pinnacle High Performance...
How can I tell if my noisy Hayward Super 1hp pump noise is in the motor or the pump?
99.9999% OF THE TIME its the bearings going bad, and need t be replaced asap.due to a bad shaft seal... search your area for your local pool pump motor repair guy with free testing. should be around $75 to repair it if caught in time.. here in florida lizards,frogs,grass and snakes and the such get into the motor and you can get that grinding sound but it will soon fade, but can restrict airflow and make your motor run hot and fail prematurely.. so if the noise doesn't fade in say a hour or two.. have it checked .. here is how to remove most pump motors just click on this link.. hope it helps ya .. jay florida
Jun 22, 2010 | Hayward 1HP Super Pump II Inground Pool...
Start pool up this year pump is louder makng whine noise, works fine and it is not getting hot Is the pump going
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
May 22, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
2 yr old inground pool Hayward pump louder than normal. Bearings were checked and seals replaced prior to opening this summer.
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
Jul 10, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pump starts and stops frequently . pump will start but not run. Sounds like it will not get up to speed before it stops.
That sounds like the pump is cycling. Is there air in the pump basket or is it full of water? If there is air in the basket, you have a leak somewhere. Could be the lid has a crack, or the o-ring, under the lid has gone bad.
The pump motor may be going out on you also. If it is hot to the touch, there is a safety feature in the pump that will shut it off before it becomes too hot.
Jun 30, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Apr 21, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Pool & Spa Logo
200 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
