Question about Black & Decker Garden
I have an old Black and Decker CMM650 cordless mower. Generally it works really well. Today the height adjustment failed, the mower flopped down to lowest position, and it will not lock into place at any higher position. I think maybe a small pin to hold the adjuster cam is broken or fell out of place. The immediate problem is that I can't figure out how to get the adjuster mechanism out of the mower, to fix it. Any suggestions, directions?
Noggin
  • 944 Answers
SOURCE: Graco Metrosport stroller Model No 611198E
contact these guys for replacement parts; http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11 Hope this helps :)
Posted on Jul 27, 2007
  • 743 Answers
SOURCE: fixating mechanism in handle is broken
i can't figure out where your stroller handle broke! if there's a possibility that you could send me an image (close catch) on the broken part and rear view of the stroller, email it to me in jpeg or pdf type..... here's my email address... jyzomnix1@yahoo.com
we'd like to help you much...
Posted on Mar 02, 2008
blueextc3221
  • 15935 Answers
SOURCE: Rearview mirror fell off windshield! Not broken...
the mirror should simply slide over the metal mount (button) that is glued to the window.
loosen the set screw on the mirror mount...
hold the rear view mirror mount on the glass just above the metal mount (wide end of plastic opening facing down)
slide it into place...
secure it by tightening down set screw you loosened earlier.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 22, 2009
SOURCE: wiring diagram for a cordless Black & Decker CMM1000 Ver 2 Mower
All set, figured it out.
Posted on Jul 19, 2009
  • 133 Answers
SOURCE: Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Posted on Sep 01, 2009
How do I engage back the height adjust on my black and decker lawn hog
if there are no adjustments at the rear wheels install new wheels to accommodate mowing hieght
Dec 05, 2014 | Black & Decker Black and Decker Mm575 18"...
I want to register my 19" 36V cordless mower-self P SPCM1916 Black and Decker
There should be paper work to fill out when you purchased the machine.
Sep 25, 2014 | Garden
36v black and decker wheel height wont stay
Check the B&D website for support - there's probably a pin or a spring that needs replacing.
Jun 29, 2014 | Black & Decker Cmm1200 24v 19" Cordless...
Wheel height on the b&d 36v cordless
servicenet.blackanddecker.com/.../Instruction%20Man...
Jun 29, 2014 | Black & Decker 19" Electric Lawnhog...
How do I repair height adjustment on a CMM1200?
The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
Aug 05, 2012 | Black & Decker Cmm1200 24v 19" Cordless...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
I own a cordless Black & Decker 19" rechargeable mulching mower, CMM 1200, 24V. There are days that it starts beautifully, and others where it remains quiet and uncooperative. Temperature seems to...
Mulching mowers are notorious for needing to be cleaned out frequently. The problem usually is the cutting height. The lower it is, the faster it gets clogged up.
Cutting wet grass doesn't help this situation either, it actually makes it clog up much faster.
Set the cutting height to about 3", and wait until the grass is dry before you cut it. This should help with the cuttings buildup.
As a landscaper, I deal with lawnmowers on almost a daily basis, and on cold mornings, the mowers are sluggish and don't want to run well.
If you keep your mower stored in a weather proof building with a consistent temperature and humidity level, there shouldn't be many issues with startup. Start it up and let it idle at half choke before cutting.
I hope this helps you.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Jul 31, 2011 | Black & Decker Cmm1200 24v 19" Cordless...
I need to know how to set the mowing height and do not have a manual
Almost all mowers' cutting height is adjusted by little "tabs" at each wheel. The tabs need to be pushed in to adjust.
May 03, 2010 | Black & Decker 19" Electric Lawnhog...
Adjusting the wheel height
its in the left side at the back end. a plastic orange color lever that you have to press up while pushing the mower up or down
May 25, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
422 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
