Question about Brother GX-6750 Typewriter
My typer writter keep reseting it self and i cant get it to type the correct letters how do i reset it properly
  • Brother Master
  • 3,594 Answers
If the spokes of the P/W are not damaged or getting tangled in the ribbons you probably have a broken P/W homing pawl. You need a tech.
DickyO
Posted on Sep 01, 2010
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
When I push the letters on the keyboard, different letters or symbols are appearing. I pushed "Code" "Q" to reset, but it will not type the proper letters.
BACKGROUND - When you turn on the machine, close the top cover, or press [Code]+[Reset} (on some models) the print head moves to the side, the daisywheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
If a reset does not work the reset tab may be out of alignment. If a reset does not correctly reset the daisywheel, I would
  1. Turn off the power, open the lid. On the bottom of the case there is a metal frame on the side of the frame (where the carriage goes were it homes) you will see a small metal tab pointing towards the middle of the machine. When the machine resets its self, it uses that tab as a reference.
  2. That tab can be easily bent which causes the reset to be incorrectly done. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It does not take much pressure and it does not need to be moved very far at all. Just nudge it towards the back (or the front).
  3. Power up the typewriter, close the lid and test it. It might take a couple of tries in either direction to get it right. Be ready to turn off the power if you bent the tab too far the tab will not enter the print head correctly, and the carriage will jam. Just nudge the tab in the other direction.
CAUSES - This reset tab most often gets out of alignment by a child playing with the machine, or when a foreign object is in the machine when the print head is moving.
Dec 23, 2010 | Brother ML-100 Typewriter
WHEN TYPING A HALF SPACE IS SKIPPED OCCASIONALLY AND WILL NOT CORRECT THE LETTER TYPED, IS THE LETTER WHEEL REPLACABLE?
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the print head.
    1. (When the machine resets its self, it uses that tab as a reference.)
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It doesn
Nov 30, 2010 | Brother EM-430 Typewriter
When typing the letters are not what i type ?
When you turn on the machine (or press [Code]+[Reset}) the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
If a reset does not work the reset tab may be out of alignment. I would
  2. If it's still typing the wrong or unreadable letters then turn off the power, open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the middle of the machine. When the machine resets its self, it uses that tab as a reference.
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It does not take much pressure and it does not need to be moved very far at all. Just nudge it towards the back (or the front) power up and test it. It might take a couple of tries to either direction to get it right. Be ready to turn off the power if when the print head resets. If you bent the tab too far the tab will not enter the print head correctly.
This reset tab most often gets out of alignment by a child playing with the machine, but if a foreign object is in the machine when the print head is moving.
Nov 23, 2010 | Brother ML-100 Typewriter
I can't type in yahoo mail without the letters not registering. I am not having problems typing anywhere else. Is this a virus?
If you are a fast typer... Then your computer may be to slow to keep up with how fast you type. I do not believe it is a virus.
Aug 07, 2009 | Yahoo Mail
The keys don't type the correct letter
Loosen the screws that hold the silver guide, one on each side of the carriage. Adjust to touch platen with 2 sheets of paper installed. When you reset next time it will reset to the right letters.
Jul 01, 2009 | Brother GX-6750 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
My wave logitech kkeeyybbooaarrdd keeps typing letters more thaan once unless I hit the rreessett bbuuttttoon all the time plz help me to figure out how to make it stop.
Go to start, settings, control panel, then keyboard, and set the typerate for the keyboard. It has two settings. If someone has set it incorrectly in the BIOS then you may have to reset it there.
Dale
Jan 03, 2009 | Computers & Internet
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
46 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
