Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
How do I remove the bonnet nut from a blanco 1-handle faucet (like their "classic" model?
    Problem Solver:
  • 6 Answers
If you mean the top faucet handle, there is a small round plastic cap. You need to remove this and then remove the grub screw, handle will then pull off. Hope this is what you meant, if not post again. Thanks Paul.
Posted on Aug 31, 2010
  • padstack Sep 01, 2010
    Nope. I need to remove the cap. It looks like part 2a on the diagram:http://www.blancoamerica.com/SPECIFICATI...
    I tried prying it off, but it's just getting scratched up. It's not budging.
    I'm trying to get everything apart so part 3 will swivel while part 6 stays in place. Will this faucet do that, or is it not supposed to swivel? It was in our house when we bought it so I don't know for sure.
    Thanks!
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
I have never done it before, so I need step by step directions in removing an old blanco single handle faucet and now putting in the new one
Turn your water supply off to the existing faucet.
With a crescent wrench and plyers remove the supply tubes from the shut off valves.
Unthread the sprayer hose that is attached to the brass connector under neath your faucet in the cabinet.
Unthread the lock nut and fastening plate which is on the same brass fitting as your spray hose.
Remove faucet from the sink.
Reinstall the new faucet in the reverse order.
Feb 25, 2010 | Blanco Classic Single Handle Faucet with...
I can't get the cap off the top of my Delta faucet loose in order to repair it. It's the older kind without the hex nut at the top, only the little ridges around the bottom edge. How can I get it loose,...
Delta makes wonderful faucets....HOWEVER.....this was a DUMB design. Channel locks won't work because the metal of the bonnet is SO thin that any squeeze deforms it and locks it up. Strap wrench will sometimes work. There is a specific Delta Bonnet Nut Wrench. Just a piece of plastic really, but it works when nothing else will.
Might be hard to find, but here's a possible source/picture:
http://img01.static-nextag.com/image/Delta-Faucets-Removal-wrench/1/000/000/651/007/65100747.jpg
If this tool doesn't work (though it usually does), the next step is careful hacksaw works and a new bonnet nut.
Good Luck.
Aug 29, 2009 | Delta 2402 Classic Single Handle Kitchen...
How do I take off handle
Yes, it will be a small allen key that needs to be loosened before you can remove the handle.
Jun 24, 2009 | Blanco Classic Single Handle Faucet with...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
My blanco kitchen mixer does not swivel. It is stuck in one place
You need to remove the handle and then remove the top cover to the housing. After the cap is removed you can pull off the spout. It probably needs new washers. You will see what you need to fix it at this point. Just remember to turn off your water before doing this.
Mar 22, 2009 | Blanco CLASSIC 1 Handle Pull-out Spray...
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
446 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
