Question about Kenmore Elite HE4 Electric Dryer
My dryer was working of I have to say never really has dried as well as I thought it should but it was at least working. However now it will not turn on at all. It was at first just beeping and all the lights were lighting up when it was not it use mind you. So I would unplug wait a min or so and plug back in . It would do it again so I would unplug until I needed it. Then when I went to use it I plugged it in again and nothing. I went to days with it unplugged, a repair man comes out plugs it in and you guessed it it worked. Now I use it for two three days then the beeping starts again and I Unplug and when I go to plug back in now it won't come on at all. Any idea? Single mom in Florida Help !
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Amana NED7200TW dryer. Has heat, tumbles, clothes don't dry. Vents have been gone through and cleaned. This happens in the sensor dry and time dry modes. Any thoughts? Thanks!
Just a question. Does your blower work. If your blower does not work it won't dry. Check blower belt. Mine broke and had no air blowing. Just a thought.
Oct 21, 2016 | Amana NED7200TW Electric Dryer
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Our dryer is about two years old. It is heating up, but only to a warm temperature. Clothes are not really drying and dryer is not hot even when on high temperature. Any thoughts?
If you have already cleaned the lint screen, have you checked the venting system? It is the 4" flexible hose that usually connects in the back of the dryer and leads all the way outdoors. Many times the vent is stopped up causing the dryer to overheat and run longer, maybe not even drying the clothes.
Apr 15, 2011 | Dryers
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer problems
either the rear bearing or the idler is worn, my thoughts would be the rear bearing.
Sep 22, 2008 | Frigidaire FEQ332E Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
