Question about Keurig B60 Coffee Maker
Will not brew and says to descale - Keurig B60 Coffee Maker
  • 3 Answers
Run vinegar thru the resevoir three times, let the last cycle sit in overnight with the unit on. Then run three water only cycles in the morning, all should be OK
Posted on Aug 30, 2010
I have a Keurig Vue. I have descaled and cleaned the product on schedule but it leaks water from all around the brew head and only 5-6 oz of coffee make it into the mug. I tried to clean out the pin also...
Remove and clean the Brew Head, with the V700 the way to remove would be to open the lid with the handle, place your fingers around the Brew Head, there are tabs to each side, press tabs and pull down and toward you. Wash this out thoroughly in your kitchen sink. Now before replacing the Brew Head, with the handled lid up, turn the back of the brewer so that it is facing you...Look straight down into the top of the brewer, you will see the needles, use an old toothbrush to clean them. Replace the Brew Head and descale the brewer with White Vinegar (do NOT dilute with water) or Keurig descale solution (purchased only through their website). The video to watch the descale instructions is: www.keurig.com/customerservice
Hope this helps!
Oct 28, 2013 | Keurig Vue V700 Brewing System - 110774
Descaling won't brew
Desacle now or it won't reset to factory settings.
Mar 11, 2012 | Keurig Platinum B70 Coffee Maker
My capresso coffeeTeamGS maker will grind the coffee but will not brew it????
Hi. Your brew unit is by passing the water that is supose to brew. You'll have to clean the brew unit. Jura brewunits are not easly removeable, + you can't buy parts unless your a authorised repairer. Try doing a manual descale cycle. You need to add descale solution to the watertank and operate the hot water and steam functions, which allows the solution to enter the system. Open these functions until water and steam are pumping through, then switch them off and let it sit for a few minutes, then repeat the above 5 or 6 times. This allows the solution to break up any build up. OK, now you have manualy descaled the steam and hot water circuits. Now allow the machine to try and make coffees." we are only trying to clean the machine, so dont drink the coffee." Try 5 or 6 times to see if this is starting to brew better. WE DO NOT LEAVE THE DESCALE SOLUTION IN THE MACHINE. We need to flush the system with fresh water as per above. Descale is corrosive, so we need to get it all out. I hope this has worked for you, other wise you'll have to take it to an authorised repairer. Dazza REPAIRER
Sep 24, 2011 | Jura Capresso CoffeeTEAM GS 46405
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Low water pressure, so takes ages to produce a cup of coffee. Has been de-scaled regular
If you get good flow with the portafilter out, you may need a new pump. When you descale do you run the descaler through the brew head? That is one problerm that people make is running the descaler through both the wand and the brew head. Sclae will build up in the pipe in the brew head and restrict it.
Feb 28, 2010 | FrancisFrancis! X1 Espresso Machine
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Keurig B60 Coffee Maker Logo
170 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
