Question about Gaggenau Dishwashers
My dishwasher has a horriable smell. I can't seem to find anything stuck at the bottom, any suggestions?
  • 5,081 Answers
Try chopping a few ice cubes in the disposall dry (no water running) only until the ice is crushed. Then run water through it while running. This will help to clean under blades and to scrape the sides etc. Then get some citrus peels and run those through (with water running). I like to use lemon peels.
There is also a dishwasher cleaner that you can buy from your local grocery store by the d/w detergents and the jet dry.
Posted on Aug 31, 2010
LG dishwasher stinks since new model #LDF6920ST
list given is the wrong stuff to clean any dishwasher
LG LDF6920ST Dishwasher
thats an old dishwasher now
use recommended dish washer cleaners regularly
off the shelf deodoriser and sanitizes on an full empty cycle
check the filter at the bottom is kept clean each load clean
temp of wash water may no be enough
helps if you wash off any food stuffs on articals with hot water before placing in the dishwasher
Apr 06, 2017 | LG Dishwashers
What causes the pungent odor in dishwasher? It seems that the all the water are not being dried
Hi, this is a very common problem and can be sorted out easily, rather than explain it here i include some weblinks that explain it all in detail. plus my favorite below.
http://www.ehow.com/how_2330730_remove-odor-from-dishwasher-.html
http://www.mrscleanusa.com/en/cleaning-tips/kitchen/clean-dishwasher.html
Here is one that takes the smells, hard water stains etc out of your dishwasher and plastic and glass ware. Fill up dishwasher, with plastic glasses, glass ware, dishware. No metal, of any kind! anything you want sparkly and clean.
No detergent! Fill up a small bowl at the Bottom of the dishwasher with vinegar, 1 cup of white. Run the cycle, do not dry. Fill up with 1 cup of bleach, run again. This takes care of all hard water stains, germs that are causing smell etc. Also check for food at the bottom of the dishwasher.
The site below explains WHY you get those smells.
http://www.doityourself.com/stry/what-causes-dishwasher-odor
Aug 19, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
Bad smell in dishwasher, have cleaned and even used bleach. The smell just comes back. even smells on the dishes. the smell is like a stink bug.
Three things, dryer coil, food stuck inside.
Most washers have a one way valve on the drain and a water trap
created with the line, so no water or smell can go into the machine.
Check the valve, remove the hose,that should be under the sink,
wrap a cloth around it and blow,it should not be able to blow into it.
Then make sure the hose at some point go higher then where it
connects to the drain.
Fill a bucket and fill the washer until you see a little in the bottom of the machine, watch it for a few minutes to see if it drains, it
shouldn't, dump in a bottle of white vinegar and run the machine, make sure dry is off. Then run it again, do not add anything.
Feb 17, 2010 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher smells awful. It's not food on dishes..help!
Try this site on YouTube:
http://www.youtube.com/watch?v=JhchaOhpQQo
You probably don't need to go to this guy's extremes (but he's thorough!). You probably just need the part about how to clean the strainer and bottom of the washer. I think this'll help. There are other videos, some selling products (that I haven't used). Also some of the videos are helpful, you'll just need to take a look.
Best regards, --W/D--
Aug 08, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher water draining????
Make sure the odor is coming from the dishwasher.
Pull the bottom basket out and check for food that might be stuck in it. And check for food particles in the bottom of the dishwasher.
Then pour some baking soda into the dish liquid compatment. Run it through a complete cycle. This should deodorize and clean the dishwasher. i hope it helps. Please remember to leave rating.
Jul 19, 2009 | GE 24 in. GLD5860LSS Stainless Still...
Foul odor
first hting do you use a rinse agent( jet dry ?) perhaps s you're not selecting heated dry as an option.as far as the smell if its musty form water left behind,using jet dry will evaporate more of the water (a small amount on a paper towel and wipe down the inner door and walls will also decrease moisture, doenst to be done every time either on ly as needed might be once a year. if the smell is anything else id look into perhaps hoked to a garbage disposer?? smells permeate back into d/w.
Mar 10, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Bosch diswasher
If it is new- then the fishy smell is almost certainly the motor and circuit boards 'cooking' in- most motorized electrical devices have an initial pong. However if it persists after say 10/15 cycles begin to suspect an incipient fault.
May 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
124 people viewed this question
Top Gaggenau Dishwashers Experts
Owen Barnes
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
