Question about Porter Cable 18 Gauge 2 " Brad Nailer Kit 3/4" - 2" Brad Nails Inclu
I have a Porter cable 18 gauge nail gun. I think that a seal is blown because when you try to make it set a nail it just exhausts air. I took the top off and checked the seals but i could not see any problem. I see that Porter Cable has a rebuilt kit. How difficult is to repair the gun? I'm very handy and try to repair most of my tools when there is a problem.
    President:
  • Porter Cable Master
  • 1,388 Answers
Check the parts breakdown for your model and see if seal #894737 is listed. This seal is cause of problem that you describe. It is included in the rebuild kit or available separately. If this seal is not listed, then problem is fine scratches on oring contact surfaces in head. Use magnify glass to examine surface and remove fine scratches with 400 grit paper. Apply silicone paste lube to all surfaces that contact orings and seals. (Silicone lube is available at Lowes in plumbing department, used for faucet orings). Parts for gun are available at Dewalt service center or at www.toolpartsdirect.com. Good luck with your repair.
Posted on Aug 31, 2010
Why is only air comes out of Nail gun of Porter Cable DA250A?
a blown seal , trigger malfunction , piston ,or damaged drive pin
Jul 09, 2016 | Porter Cable Air Tools & Compressors
Why does bn200a nailer shoot double nails
Check your compressor Pressure - it need to according to nail-gun specifications.
Usually it is mechanical pressure switch failure. Replace all with digital Controller.
Jul 14, 2014 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
What is the angle of the 15 gauge nails for this gun and what nails are compatable
You did not mention the brand or model of your gun, however, you can determine the angle needed by placing a straight edge in line with the path of the driver and measure the angle from this edge to rails.. If the straight edge to the rails measure 90 degrees or makes a right angle, you need "0 degree" nails, if it measures 80 degrees, you need "15 degree" etc. Most generic nials 15 gauge nails will work. No need to by branded nails unless your gun requires an unusual angle. Good luck.
Jul 31, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Jan 23, 2010 | Porter Cable Air Tools & Compressors
Will work fine for one or two nails and then nails jam in the gun or it shoots two or three at once.
This is iffy... but PC nailers are nit picky. If you used someone elses nails, it can (and will) jam and mess up.
So, if Porter Cable nails are being used, clean and lube the nail shoot (with a few drops of air tool oil).
If that does not work, Invest 19 dollars in a new, 18 guage nailer at Harbor Freight. I have 2 of those and they have been trouble free for 3 years.
Nov 15, 2009 | Porter Cable 1" 18 Gauge Brad Nails...
PC nail gun does not work all the time. nails do
You have to oil the nailer with pneumatic oil, or you're using the wrong size nail
Nov 10, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from www.dewalt.com. Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Apr 27, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Porter Cable BN125A won't set nails below surface
Not sure about the seal, but I do know the pressure has to stay up for this nailer to be effective. Try oiling the gun to free up the mechanics and don't use old nails.
Jan 23, 2009 | Porter Cable Cable BN125A Factory -...
Porter Cable 18 Gauge 2 " Brad Nailer Kit 3/4" - 2" Brad Nails Inclu Logo
416 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
