Question about Royal Sovereign ARP-3012 Air Conditioner
The water tank has to be enty every1 1/2 hrs - Royal Sovereign ARP-3012 Air Conditioner
Must be very humid where you are. I have to empty the tank about twice a day and I find this a real pain since the plug is in the back of the unit...
One thing I was going to try is to buy a few feet of 5/8" hose, this is internal diameter. I don't a drain to send it to, but if I can find a clear hose, it can help figuring out the water level and make it a little easier to empty.
Not a perfect solution, I know.
Posted on Sep 05, 2010
Yes this is normal. Your a/c pulls water from the air that is blowing out. If it is real humid then you are going to get a lot of water in the tank
Jun 24, 2013 | DeLonghi Pinguino PAC-02 Air Conditioner
What is Salt Bridging in a Culligan Water Softener
Salt bridging can occur in any water softener "salt tank". A salt bridge occurs when a hard crust of salt develops across the salt tank when the salt wicks up moisture. The salt does not fall down in the salt tank in between regenerations and a "bridge" occurs. It may look like the salt tank is full but there will be a hollow area at the bottom of the salt tank and not enough salt to develop the proper brine for regeneration of softener. This generally happens when the salt tank is a least 1/2 full of salt. If the system has a separate salt tank, shaking the tank will break the bridge usually. Gently poking a stick at the bridge can break it up also but can damage the salt grid if you poke the stick too far down in the salt tank. Certain salts, such as pellet salt are highly prone to this problem. Using Dura Cube, Hardi Cube or Solar salt will greatly reduce the chance of bridging. Any time a salt bridge occurs it will take 3 regenerations of the water softener (in 24 hrs), after fixing it, to regain the reserve capacity and totally soft water.
RJ
Oct 27, 2011 | Culligan Sediment Water Filter
6 stage ro system under counter style will not stop draining or producing ro water at all I removed unit changed 3 pre filters and a post polisher now I gotta problem How long will this unit run to fill...
If the RO is not shutting off and there is no water from tank there are several things to check.
1. The product water tank is probably low on air. The tank may be full but no water will come out. Put enough air in tank to force out all the water then reset air pre-charge to 7psi for 3 gallon tank.
2. The capillary tube / check valve of RO system is bad. This puts back pressure on membrane to help create water.
3. The Automatic shutoff is not working, causing the unit to run constantly.
I would have to know what model RO it is to narrow down the problem further.
Depending on the Membrane production 10, 25 gpd, etc. and the TDS of water it may take 24 hrs to fill the tank.
RJ
Oct 07, 2011 | Culligan Under Sink Water Filter
I have a 1 yr old new Danze Orrington two piece toilet. DC013230-DC012223. I have 3 of the same actually but only one is giving me problems...the one on the first floor of the house. The flush is weak...
Your thought is probably correct. Usually toilet tank lids and feet on them to allow air enty. You might have to add rubber feet (self adhesive) or balance the lid on the tank differently.
Jun 03, 2011 | Danze - Toilet - One-piece - Orrington -...
My water softener emptied im not sure how long it was empty for but I dont think it was too long I filled it with salt and now it doesnt work. It still regenerates but im getting hard water still any...
Do you mean the salt tank was empty? If so fill salt tank half way wait about 6 hrs for brine to develop. Manually regenerate softener 2x within 24 hrs. When the salt runs out the resin becomes saturated with hardness minerals. It takes at least 2 regeneration cycles back to back to completely restore soft water. Also the hot water will take some time to get soft. It will help to flush water heater after cold water is consistently soft.
I hope this helps,
h2oservices
Feb 26, 2011 | Culligan Compatible S7011C RS23SED5...
Fluval m200 heater is lit and warm but still hasnt heated tank after 36 hrs..200 ltr tank is this normal
Hello. You haven't stated the room temperature and what temp you are trying to raise your tank to, but it sure sounds like the tank is too large for the heater wattage you chose for the tank. The basic rule of thumb is 3-5 watts per gal (about .75 to 1.5 W per ltr) to raise the tank 5 deg-F (approx 2.5 deg-C) above room temp. If you need to raise the tank temp even more, then you will have to choose a larger heater. Using the rule of thumb I would choose at least a 300W heater for a 200ltr tank. Also, do not forget to include the capacity of your refugium/sump, if you use one, in the calculation of your water quantity because you are heating that mass of water as well as your tank.
Jan 26, 2010 | Kitchen Appliances - Others
Have a kent r/o system dont know how to hook it up is there any way someone can help
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 13, 2009 | Culligan Under Sink Water Filter
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
To recharge RO System Tank:
3) Remove stem cap.
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
Mar 19, 2009 | Culligan Under Sink Water Filter
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Royal Sovereign ARP-3012 Air Conditioner Logo
159 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
