Question about White Rodgers Water Heaters
How to reset a white rodgers 64020 ? - White Rodgers Water Heaters
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
How do you reset a white rodgers hot water heater?
The red button at the middle is the manual reset button.
Apr 24, 2010 | White Rodgers 0754-1 Electric Water Heater...
White rodgers motor turning heat not going thru
This item is a buy -out from Thermodisc send a inquiry to there contact us.
Link: Contact Us
Dec 10, 2009 | White Rodgers 0754-1 Electric Water Heater...
Water Heaters Logo
496 people viewed this question
Top White Rodgers Water Heaters Experts
Steve
Gene Haynes
Are you a White Rodgers Water Heater Expert? Answer questions, earn points and help others
