Question about Toshiba Satellite A105 Notebook
It looks like the bulb in the screen is burnt out. The screen is completely dark when fully chared.
    Scholar:
  • 88 Answers
You can determine if the bulb is bad by simply connect a monitor to the fifteen pin AGP port located at the side of your computer usually color blue. If your computer display the desktop on the monitor,you should change the bulb in your computer display.To change the backlight you need to follow these steps :Power off your Toshiba laptop and make sure the AC adapter is unplugged.
Remove the screws on the side of your laptop screen. Once the screws are removed, you can remove the plastic bezel (screen guard).
Pop the bezel out, exposing all of the LCD screen. Pull the LCD screen gently away from the computer by the corner. Be mindful that the screen is still connected to the computer by a ribbon cable.
Remove the tape over the ribbon cable where it connects to the screen, and gently pull the cable to disconnect it.
Turn the LCD face down, and remove the piece of tape that holds the top metallic foil against the back of the LCD.
Lift the metallic foil to expose the backlight. Remove the single screw at the end of it that holds it in place. Unclip the wire at the end of the backlight from the inverter (power source to the backlight), and remove it from the LCD. Replace it with the new backlight (available at any electronics store or online), and reassemble the device the same way you took it apart.
Posted on Aug 31, 2010
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Posted on Aug 30, 2010
I have a SONY Flat Screen TV 3LCD and the screen went black.
open the heatch on the lower right hand side and flick the lever and pull the bulb housing out look at the internals of the bulb to see if it has failed out it will have some little particles floating around inside or a dark burnt spot of completly broken coil if you have any of that get a new bulb from ebey ok they are as easy the change as to remove and inspect but be careful they contain mercury and are toxic so handle with care and good luck ok
Jan 11, 2011 | Sony Televison & Video
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Olympus Fe-4000 screen is completely black no image available
Stephan is exactly right. I have a FE-4000 and the LCD screen is most likely dead. As Stephan said, the screen should be replaced by a professional.
Cheers to all
dmklunk122
Dec 16, 2009 | Olympus FE-4000 Digital Camera
The screen is really dark almost completely black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 20, 2009 | ViewSonic N3250W Television
LG REAR PROJECTION TV DARK SCREEN PROBLEM
very possible unit has bad optical engine .May not be worth repairing.Optical engine is complete unit that includes lamp,LCD panels, fans,optics and other parts.They come complete and cost about 3-6 hundred dollars ..thanks
Jul 30, 2009 | LG 62SX4D 62" Television
How do i charg an mp3
The way I figure it out is to just unhook it and look at the screen. Go into your music and look at the upper right corner. there's a rectangular battery looking thing. If it's a solid dark blue color, it's full.
Jun 06, 2009 | GPX ML648B MP3 Player
ZUMO CHARGING STATUS
I have had Zumo 550 for 2 years now, and it does exactly the same.
I think it is just the way the unit is, and is not a fault.
Feb 14, 2009 | Garmin zumo 550 GPS Receiver
Sony VAIO PCG-K25 PC Notebook
have you tried your power management settings?
Dec 07, 2007 | Sony VAIO PCG-K25 Notebook
Toshiba Satellite A105 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
