One end of the coax cable is connected to your antenna. The other end connects to a coax port on the back of the receiver labeled "TV/Antenna Cable In". All DISH Network receivers have this port on the back except our "K" series receivers. These receivers require a module to plug into the back of the receiver. Connect the antenna cable to this port, "TV/Antenna Cable In", if the receiver has the port available. I hope this helps.
The only way this will show on channel three is to have the receiver connected via coax to the TV and since it is displaying on Video 3 it either is not or it is connected in more than one manner and the Coax port on either the receiver ot TV may be bad.
Lets just ensure that tha coax from the back of the receiver is attached to the CH3-4 out port and then run to the back of the TV. If the TV has a dual coax input it will need to be connected to the analog or antenna port.
If the receiver does not have a coax port for TV1 you can get an rf modulator to facillitate this conection.
If all else fails try taking the red and white cables that are connected to the TV from the receiver and connecting it to the surround directly.
I hope this assists you.
Thanks for using Fix Ya and being a valued Dish Network customer.
First unplug your current antenna from your tv and plug it into the "Antenna In" coax port in the back of your converter box. Then take coax and run it from the only other coax place on your converter box back to where your antenna was previously hooked in on your tv. If after you run "scan" on your converter box it is saying " no signal " or "signal lost" or something along those lines, go to www.antennaweb.org to see what type of antenna will best fit your location then print it off and bring it to a local store that sells antennas, they should be able to direct you to the right one.
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
Erica,
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Jim
Plug the Red, Yellow, and White cords into their respective "IN" ports on the VCR. Run a coax line from the "out" port of the VCR to the coax port on TV. Some VCRs require you to tune to channel 3 or "LINE" which is typically the channel before 2 for this to work. To make things easier, you may want to purchase a modulator. This would allow you more easily set this up. The Mini-modulators aren't very expensive and can be purchased at virtually any electonics store.
