Question about Brother XL-6562 Mechanical Sewing Machine
The entire mechanisim that holds the needle to the shaft ...this part won't stay on the shaft. Help
    Genius:
  • 1,788 Answers
Get a copy of the sewing machine manual at brother.com. Sounds like you need to tighten the screws, use a coin or screw driver
Posted on Aug 31, 2010
FS320 serger needles won't go up and down. New
if the machine is still under warrenty, take it back
if it's not under warrenty, take it to the place you bought it from & tell them
May 28, 2012 | Yamata Sewing Machines
Needle screw won't stay tight and needle comes out
the screw & the needle clamp may have to be replaced
May 11, 2012 | Janome Magnolia 7330 Sewing Machine
How do I change a needle on a Janome jl-634
The jl-634 is a serger so should have two needles. There are two small screws (one on the left and one on the right) of the needle bar. First raise and remove the presser foot (makes changing the needle much easier) Rotate the needle bar to its top most position. Loosen the small screw for the needle you wish to replace, do not unscrew it entirely as it is finely threaded and difficult to re thread. Remove the needle while observing the orientation of the shaft (which direction does the flat side of the shaft face) Insure that replacement needle is correct for your machine. Serger needles are usually different from standard sewing machine needles. Insert new needle with correct orientation, and re-tighten the small screw previously loosened. Reinstall and tighten presser foot. Rotate machine through entire stitch cycle to insure that needle does not strike or rub on anything. Re-thread needle and check for proper operation.
May 06, 2011 | Sewing Machines
As the shaft that holds the needle moves up and down in the sewing process, it hits the plastic top of the serger above the shaft just to the left of the first tension wheel.
Lots of times when a needle strikes the needleplate and breaks, the shaft that holds the needle slips in relationship to the rest of the machine. There's usually a set screw on the needle bar (shaft that holds the needle) of the overlock, that you can loosen, adjust, and then re-tighten. You need to know which way (up or down) to adjust the shaft, and how much. Be extremely careful though!
Overlock machines are tricky. I usually mark where it was, then I move the shaft down 1/8". If that doesn't work I move it up 1/8" from it's original position. If that doesn't fix it then it may be more complicated, and require a trip to the sewing machine shop.
Before you do anything change your needles in case they are bent....Pulling the fabric while you're serging is a sure way to bend the needles and/or break them on the needle plate. Let your machine pull the fabric through, just guide it with your hands. Good luck and I hope this helps!
Jan 31, 2011 | Sewing Machines
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
needs a new needle clamp screw & possibly the needle clamp too
try sewingpartsonline.com
Jan 11, 2011 | Brother Sewing Machines
I have a Singer #7430 hardly used, but I thought the needle should be changed as it sounded dull, now i cannot get the needle to stay in when i start sewing the needle falls out and i have broken 3...
some needle clamp screws have a indention where a screwdriver can be put in to turn the screw,,
check to see if your has the indention & if not you need a new needle clamp screw
Nov 04, 2010 | Singer 7430 Sewing Machine
The entire mechanisim that holds the needle to the shaft on the Brother XL 6562 has come off. There are no screws or other mechanisms to hold this on. How do I get it to stay on?
Take it in because that sounds serious, call Brother at 1-877-276-8437 and find an authorized service center to take it in to. You do not want to void your warranty.
Oct 09, 2010 | Brother XL-6562 Mechanical Sewing Machine
Singer 758 adjustments for needle position and stich width
Found this below that may help confirm timing? As for the zig zag one thought is to check for end play in the upper shaft. At the left hand end of the shaft (under the top cover) there is an white plastic "bushing" with one slotted screw - this can be adjusted to take up the slack. It is possible that this bushing is split by the screw which may make it come out of adjustment. Check the other collars on this shaft are tight (hex) - by the belt and near the drive gear. P.S. double check the zig-zag cam is in the correct position (set to straight sew - centre position to install the cam - check instructions).
Timing
Turn the handwheel towards you until the needle is in the lowest position and observe two lines on the needle bar at the place where it comes out of the machine. You have to see these lines. When you find those, you have to tilt the machine on its back and you will see that on the right hand side there is a belt coming down onto a gear like piece on the timing shaft. Move your eyes to the left and the next thing that you will see is a large round gear on the feed shaft. Now that we have determined the difference between the feed shaft and the timing shaft, follow the feed shaft to the left and there will be a small metal piece there with two metal screws on it. Next to that to the left is a stationary metal peice that has a bump on it. You must see these two things to adjust your machine.
Now, to determine if your machine is out of time, turn the handwheel towards you (always turn it towards you) until the needle is in the lowest postion again. Observe the two lines on the needle bar, turn the handwheel toward you until the bottom line goes in the exact place where the top line was. Now look at the needle and hook. The hook should be directly behind the needle. If it is not, we go back to the bottom of the machine on the gear like metal piece that the belt rides on and loosen the two screws that are in the piece. Now if you will remember, this is on the timing shaft. When these two screws are loose, the hook will become moveable. Place the tip of the hook directly behind the needle without moving the needle bar (remember that the needle bars bottom line was placed where the top line was). When you have accomplished this, tighten the screws on the belt gear.
Now you have to determine whether the feed is in time. Again, place the needle in the lowest postion, rise the low line to where the top line was, and see if the line on the feed shaft is directly next to the bump on the stationary metal piece. If not, without moving the handwheel at all (because it must stay in this position to time it), loosen the two screws on the feed shaft piece and align the two lines together. Then tighten the two screws, make a few rotations with the handwheel, and again, put the needle in its lowest position and rise the bottom line to where the top line was. Inspect the two lines on the feed shaft and the hook behind the needle.
If these did not stay in adjustment, re-do the entire process, but be more careful not to move the handwheel when making the tightening adjustment. If you re-do this and it still does not stay in adjustment, you need to replace your timing belt,
Jan 01, 2009 | Sewing Machines
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
The piece that holds the needle has come off the machine
Generally, there will be a cut out inside the 'needle clamp' that will allow it to only go on the 'needle arm' one way 'round as it slides over the shaft.
The screw to tighten generally comes in from Right to Left.
If this does not help entirely, try taking a look at any other machine, mum's, friend's, in a store....etc and take note of the arrangement.
If you have a friendly local sewing shop where you buy threads etc, ask if they could show you.......plead accident, unattended young fingers, whatever......the easiest is to compare a good one ans see how it should be.
Hope this is of some little use.
May 21, 2008 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-6562 Mechanical Sewing Machine Logo
96 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
