Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Just changed out the carraige rack and cant seem to get the travel up and down right. It either goes all the way or stops too soon. Any help?
    Scholar:
  • 143 Answers
It sounds like you may have moved the placement of the trolley when you did this. The adjustment screws are to be adjusted 1/4 to 1/2 turn at a time. This might be the problem.
You may also have a damaged limit assembly on the inside of the unit or the metal drive shaft may need to be replaced. These are things better left to the pro's but if you can handle it and can track down the problem shoot for it. Thanks BB
Posted on Sep 03, 2010
2003 Ford Expedition Will not engage in drive right away. You put the truck in drive and give it gas it just revs up the engine then after a few seconds will **** into drive. Also is doing this at stop...
It sounds like you need transmission fluid and filter change. This is one of the most overlooked maintenance items. It should be changed every 50k (30k if you tow a trailer) The delay in engaging gear is sign that trans fluid is tired or REALLY cold. In cold weather this is a normal symptom on cold morning starts but goes away when warm. I'd get it changed and soon, before it turns into a $$$ repair.
Jan 05, 2011 | 2004 Ford Expedition
My Sears electric typewriter "scholar w/
could be the carraige release button on the carraige is stuck down (pull it back up). Otherwise the mach. is stuck in "tab" mode or the escapement (the mechanism that hold the carraige in place and lets it advance 1 space at a time) is FUBAR'ed, in eithor case it would need professional help.
Dec 28, 2010 | Smith Corona Office Equipment & Supplies
The rollers will not go up and down anymore; looked inside and everythink seems intact
Your set up is most probably: an electric motor turns a worm gear that turns a large spur gear that turns a smaller spur gear that rides on a rack gear. The smaller spur gear (pinion) that rides the rack (yes, as in rack-n-pinion), allowing the up-and-down travel of the massage balls, has broken teeth which may not be visible because it's hidden under the larger spur gear. They are all plastic gears with lots of white grease.
Aug 14, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
2002 Nissan Micra guzzling Fuel - Any help or
What did full service consist of? Wouldn't you have this issue checked out went it was in the shop?
Sep 29, 2009 | Nissan Micra Cars & Trucks
I want to change my big foot 60hp from power tilt to power trim how do i do that??? 90850260 that is my serial number what is the year model?
I dont knowthe year ,that should be stamped on the id plate. As for tilt and trim----- in the lowest position the leg will only move slowly out and up that is when it is in the trim mode, after that it goes into the tilt mode and the leg travels considerably faster, this works going up and down,putting the leg down, it will travel faster until the last foot or so then it goes into the trim mode automaticaly and travels slower but with more power---you cant split them.It needs the extra power to be able to"trim"" the boat whilst it has the water pressure against it at ,say 25 knots. To test what i am saying ,puthe leg down as far as it will go ,stand on the anti cavitation plate and push the button to raise the leg .You will see it will only traveh ashort way out and up be fore stopping because it doesnt have the extra power to lift you as it did in the first foot and a half.thatis the system and you cant change it if that is unclear take it to a dealer ,he may explain it better---------"youdoit"
Sep 20, 2009 | 2000 Mercury Mariner
1999 dakota rack and pinion leak
You can change the seal, but the new one will most likely leak soon after, the seal starts leaking because of problems in the rack from wear, I would try it but if it leaks soon after replace the rack, they are cheap rebuilt.
Apr 02, 2009 | 1999 Dodge Dakota
Oven with an attitude
Check the lineator actuator motor. If you remove the top cover there should be a strip of metal stuck on the cover to put pressure on the gear to keep it from free wheeling down. These is a tiny button/nipple that sits in the hole in the top of the gear shaft. Lose it and you're sunk. Work with good light and watch the grease. Good luck
Feb 27, 2009 | Baxter Ovens
Will not find home position after switching on makes clicking noise screen 's got egg timmer showing after afew minutes it stops clicking but remains with egg timmer showing help?
The carraige is moved by a toothed rubber belt and plastic gears. Unplug the machine, open the front cover, and manually relocate the print carraige to the far right. Close the cover and plug machine back in. Hope this helps.
Feb 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
Palm TX travel charger problem
It is an issue with the slot on the device, however you can charge the device using the Sync cable, it is the safest way to charge the device.
Dec 01, 2008 | Palm TX Handheld
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
63 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
