Question about Mitsubishi LT-52148 52 in. LCD HDTV
My lt-51248 will not reset and when it turns on it only stays on for 2 seconds with sound.What is the problem? Can i fix it myself? Mike
  • debo427526 Aug 31, 2010
    I took the back off,where is the power supply board located?
    Thanks
    Mike
    I took off the back and the capacitors on the power supply board look the same.
  • Mitsubishi Master
  • 3,866 Answers
First of all try all inputs!
If its doing this on all inputs "everything" and you have no lcd but sound, the issue could be with one of the back light inverters not firing, it also can be caused by a bad power supply. so check the following
1. check all inputs
2. try unplugging the tv waiting a few min's then plugging it back into the wall.
If both those do not help it will need repair, now I do not recommend Mike if you not tech savvy to dig into this tv, I would prefer you take it in to get it worked on.
Let me know
otherwise please od click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 31, 2010
  • Mitsubishi Master
  • 5,138 Answers
Bad capacitors ,look on power supply board Capacitors should be flat and not vented, swollen, or puffed up on Top! 1000uf 16v 220uf 10v 3300uf 10v 330uf 10v
Posted on Aug 30, 2010
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
How do I fix a ricoh afico sp 100 sc542 error
1. ATTACHED PRINTER TO COMPUTER AND TURN IT ON
2. OPEN PRINT PROPERTIES
3. CLICK ON SMART ORGANISER, IF U DO NOT HAVE THIS DOWNLOAD AND INSTALL FROM RICHOH WEBSITE
4. CLICK ON ABOUT
5. MOVE MOUSE ARROW KEY TO PICTURE ABOVE TEXT BOX INSIDE BLUE AREA
6. HOLD SHIFT AND CONTROL KEY AND DOUBLE CLICK RIGHT MOUSE BUTTON TO OPEN SERVICE MENU
>>>>> DO NOT PLAY WITH ANY OTHER SETTING OR YOU MAY PERMANENTLY DAMAGE UR PRINTER<<<<
7. CLICK ON RESET SC FUSE ONCE ONLY. (IT WILL BE SECOND LINE TOP LEFT SIDE)
8. FROM MAIN POWER SWITCH TURN POWER OFF AND AFTER 10 SECOND TURN IT BACK ON.
9. UR PROBLEM WILL BE SOLVED.
Feb 17, 2013 | Ricoh Aficio AP3800C Laser Printer
Radio turns on, stays on for a few seconds, then turns off
sounds like a loose wire in the back of the radio
Dec 03, 2012 | 2001 Subaru Forester
Wont turn on
2 days old and defective return for refund or replacement
Jul 12, 2017 | Motorola Mobility S9 Headphones
I have a Whirlpool (2004?), and when I release the reset button, the pilot goes out...as long as I'm holding the reset button down, the pilot stays lit. Even after two minutes, when I think it'll stay lit...
Almost always it is the thermal coupling, change that and try again...They're not too expensive, but you do need to get the correct one...
Alternatively, hook up a bicycle and have the teenagers generate the heat...... << Good luck selling that one. Tell them ALL of the teenagers do it.....
Mar 12, 2011 | Water Heaters
No sound at all on Mitsubishi LT-52151. Fixed before by unplugging, waiting 30 seconds, plugging back in. Was occurring more and more often to the point of having to do this every time I would turn it on....
Just fixed this on my TV today! (after 2 months of the sound intermittently failing to turn on and failing completely yesterday) Go to Mitsubishi-tv.com. Go to support. Enter your model number. You will be directed to the documentation for your model which will include a zip file for a firmware update and a PDF file with instructions for installing the update. This fixed my sound.
Mar 02, 2011 | Mitsubishi LT-52151 52 in. LCD HDTV
Mitsubishi LT-52148 lcd tv turns on for 2 seconds with sound and shuts off.Tried resetting.What could be the problem?
The lamp LED indication flashes?When was the lamp replaced?The lamp has not been replaced 1 1/2 or 2 years.The lamp life is over.Require a new lamp.
Sep 01, 2010 | Mitsubishi LT-52148 52 in. LCD HDTV
JVC LT-42E488. No picture. JVC logo comes up for a few seconds.
A firmware update might fix it. Call an authorized servicer, explain the symptom.
Jan 16, 2010 | JVC LT-42E488 Television
JVC model LT-37xm57 will not stay on
I believe it is an overheating problem...
Short term fix...place a small fan behind your TV on bottom right hand corner and your TV will not shut down
Mar 24, 2009 | Televison & Video
TFT -LCD Samsung LT-P227W
BY UNPLUGGING YOU RESET THE TV. SOUNDS LIKE IT IS GOING INTO A PROTECT MODE IF THE STNDBY LIGHT IN FRONT IS NOT FLASHING ITS PROBABLY A POWER SUPPLY PROBLEM IF IT IS COUNT HOW MANY FLASHES THAT WILL BE AN ERROR CODE
Feb 22, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Mitsubishi LT-52148 52 in. LCD HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
