Question about Daewoo Televison & Video
I have a Daewoo DTQ-14P1FC TV. It has been a reliable set for a long time. It recently has developed a condition where a thick white line appears horizontally when turned on. Once warmed up it is OK. Is it worth fixing?
  • 864 Answers
I would say no it is not worth fixing. Use it till it burns out then dont bother with it. Im trying to find the service manual or the schematic diagram but all links turn up negative. But the parts to fix it if you knew how to solder circuit boards would be about 20-30 dollars including shipping. But i couldn't say for sure what it was without looking at the diagram. Im sure this isnt what you want to hear but i would once it doesnt work at all just buy a new one or a used tv off your local craigslist. Thanks, Midwest-tek
Posted on Aug 30, 2010
Menu for Daewoo DTQ-20U4SC TV.
Microprocessor error. Try unplugging for 10 minutes.
Aug 27, 2016 | Daewoo DTQ-20U4SC 20" TV
Daewoo tv dtq 21tips hsa no sound
check if the IC got power supply and if not follow the line of feed for a bad resistor low ohms
Mar 25, 2013 | Daewoo DTQ-19P2FC 19" TV
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
Black vertical line on screen periodically- but most of the time
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 20, 2010 | Daewoo DTQ-27U4SC 27" TV
I have a 13 inch Daewoo color TV model, DTQ-14P1FC I want to connect a Dvd player to it but I don't see any place on the back for video connection. Is there a way to connect a Dvd player to this t.v.?
you need rca connectors or hdmi connectors. if you only have the round cable tv style connector, you will need a modulator to connect to first
Jul 31, 2010 | Daewoo DTQ-14P1FC TV
I got a tv on ebay
Black is hot (or live).
May 11, 2009 | Daewoo DTQ-27U4SC 27" TV
Daed. Daewoo DTQ-13V1FC
tv appears to be in standby mode.. how can i get the tv to actually turn on?
Thanks, bd
Mar 26, 2009 | Daewoo DTQ-13V1FC TV
Lines on screen
Can you take a picture of the screen and post it? It is not possible for both the horizontal and vertical stages to fail at the same time to produce a cross. A picture of the screen would help significantly.
Aug 08, 2007 | Daewoo DTQ-25S2FC 25" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Televison & Video Logo
123 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
