When i turn the tv on i get lines all over the pitcher for about 5to10min
  • 8,617 Answers
What is the model number of your set. I will need that info in order to help you.
Posted on May 08, 2008
Element tv model elgfw551 how to fix pitcher keeps going out
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 18, 2016 | Element Televison & Video
TV PITCHER GOES TO BLUE
Absence of video signal. Contact any service technician. http://electronicshelponline.blogspot.com/
Sep 06, 2014 | Televison & Video
My phylips tv screen is zoomed after some time now it is not showing pitcher and turn of
The main digital processor board has the fault. In rare occasions, a software update might make this right. Contact the nearest authorized service center for Philips. Check this link too.
Sep 29, 2012 | Philips 6000 Series 32PFL6606 32-inch...
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Pitcher has double pitcher and one is in diffrent colors .also have a line about 4" from bottom of screen.
you need new convergence chips, 2 chips stk392-110, they have to be soldered in, very common problem, you also want to t\check for burned resistors around the convergence chips.
Sep 14, 2009 | Hitachi 57F710 TV
Sound but no pitcher
Try another AV cable or another TV, if it doesnt work, that means that there is a problem with your AV PORT. and you need to send the console for repair, Call 1-800-4MYXBOX to check the warranty status
Mar 14, 2009 | Microsoft Xbox Console
All the sudden pitcher is bowed and colors are sepertated
This is convergence. First read FL231 fuse problem in tips and trick section to see if this may be the problem
Jan 22, 2009 | RCA HD52W58 52" TV
No pitcher
The power supply is not providing enough voltage to the back inverter board due to leaky or dry capacitors in the power supply.
The power supply will need to be replace or repair to restore the LCD functionality.
Sep 17, 2008 | Astar LTV-3001 Television
My dad gave me his Mr. Coffee Ice Tea Maker, but I have no instructions on how to use it. Can you please help?
Specifics may have changed for newer models -- we've had ours and used it happily for many years -- but the basics are simple.
(1) Fill the pitcher with water up to the "water" line and pour that water into the top of the appliance.
(2) Fill the pitcher with ice up to the "ice" line.
(3) Place a coffee filter and a family-sized tea bag into the top of the brew/steep basket and put the cover on that basket.
(4) Put the brew/steep basket on top of the pitcher.
(5) Slide the pitcher next to the appliance, such that the hot water exit port on the side of the appliance lines up with the entry port on the brew/steep basket.
(6) Press the "on" switch on the front of the appliance and wait for the tea to brew.
(7) When the brewing/steeping process is over, the appliance turns itself off.  Replace the brew/steep basket with the pitcher lid for pouring and storage.  Discard the tea bag and coffee filter, and rinse the brew/steep basket.
(8) Enjoy your tea!
Aug 17, 2008 | Hamilton Beach Iced Tea Maker
Philips TV 27PT543S37A
ctgarden girl, my set does the EXACT same thing! I too wondered if a cold room was an issue. The set is only 4 years old, and I didn't have this problem in my old place where the room was a lot warmer.
Can someone please help?!?!?!?
Jul 08, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
