My son was cleaning his key board on a gateway netbook and accisently sprayed the keyboard directly with windex. Now the 6,7, t, u, f,g,h,c, b do not work. It's not even 6 months old. Any resolutions? Thanks so much for your assistance
    Genius:
  • 1,478 Answers
Pop the keys out using a small knife or flathead screwdriver. Most keys pop right out and can be pushed right back in place. Look for something that might be blocking the key and remove anything you find and ensure you dry clean each key panel.
You can get a blower to blow each panel of the keys that are not responding, but make sure they are dry and clean, fix back the keys and test to see if the keys will respond.
Take care.
Posted on Aug 30, 2010
My Pioneer VSX 820K will not turn on. Son sprayed some windex on it when it was on and it shut down.
More than likely the windex fried a channel or two. If you have a DVM you can find out wich chanel or channels is bad by checking each output transistor for each channel until you find the one that is shorted.
Jun 06, 2012 | Pioneer VSX1020K Receiver
Worth trying to fix keyboard on Samsung NF310 netbook after a 6 foot fall?
Hello, considering the incident, you were lucky. I think the keyboard is worth the repair cost as you are able to use an external board and it works. The replacement is fairly simple and other than the cosmetic crack, your system should work just fine. Good Luck .
Dec 23, 2011 | Samsung NF310-A01 10.1-Inch Netbook (Titan...
How to clean keyboard keys of toshiba laptop Satellite pro S300
The best way is to use compressed air to blow the stuff from between the keys then use a paper towel or lint free cloth and spray a little Windex on it and wipe the keys down while to computer is turned off. If you have spilled liquid in the keyboard there is no easy way to clean that up.
Aug 11, 2011 | Toshiba Satellite Pro S300 Laptop...
I accidently spilt some liquid on the keyboard. Now some of the buttons do not work. How can I sort it. Many Thanks, Lyn
This is a risky solution but worked for me.With the batteries removed turn the key board face down. get a spray bottle filled with warm water. Now you are practically going to wash the keyboard.Spray the affected area with the warm water spray, allowing the water to drip down as you spray.Satisfied with the cleaning let the key board to dry but still in the face down position.Allow ample time and warmth to dry. Fix your batteries and test.
Aug 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
My 2 year old son clean my laptop with some cleaning solution and now my laptop not running P.O.S.T and some of the keys on my keyboard does not work or they dont work how they should. I have a gateway M...
I think the solution bit is went inside those keys. Try to dry the whole laptop with the use of the fan, hair dryer etc. If still the problem is there then better to take it for service center to check thoroughly because as you suspect the key may be gone bad completely.
Jan 17, 2011 | Gateway 2520915 Keyboard
My second row of keys on the keyboard will not work; ii typing with the on screen keyboard and the keys asdfjkl;' and Enter keys are not working. i did not drop or spill anything they all just stopped...
The issue could be with many cause. In order to isolate this issue I request you to perform the below steps :
====================CLEANING KEYBOARD============
To get started, find a soft, lint-free cloth and some window cleaner like Windex. Turn laptop upside down and give it a gentle shake. This will clear out dust and debris that has fallen in between the keys. If your vacuum has a soft brush attachment, you can vacuum the keyboard gently, too.
Now, spray a tiny bit of Windex on your cloth. You do not want it wet, just barely damp.
Gently scrub all the areas around the keys of your keyboard. Watch for an excess fluid squeezing out of your cloth. Should this happen, dab it up quickly.
Once the housing for the keys is cleaned, focus on cleaning the keys themselves. Gently stroke the keys with the barely damp cloth, repeating strokes until each key is cleaned.
Badly soiled keys can be (try and if are not difficult to pull them out do not attempt) pried off the board, cleaned and snapped back into place.
You can clean crevices by wrapping your cloth over a table knife and carefully and gently running it between keys. Do not push down into the mechanisms below the keys, though.
Once you have cleaned the keyboard to your satisfaction, let it set to dry for half an hour, just in case it is damp.
Also note that office supply stores sell cans of air. It's not just air; it's air that comes out of the can with enough pressure to push dust out of places it shouldn't be. The cans come with little straw-like tubes that you can attach to the sprayer so that you can get inside your removable drives and between the keys of your keyboard.
*** Uninstall and reinstall Device drivers from Device Manager ***
1. Click Start, type Device Manager in search field.
2. Click on Device Manager.
3. Click "+" beside Keyboards Device Category.
4. Right-click the listed Keyboard and select Uninstall.
5. Restart the system.
Windows will redetect the device on restart and reinstalls the drivers automatically.
May 14, 2010 | HP G60-235DX Notebook
I have a Gateway Netbook and many of keys have 3
Bruce, you need to use alt depens on the side if it shown the right side press alt on right if its on left pres alt from left
Apr 28, 2010 | Gateway 2520915 Keyboard
I cleaned my lap top with a tiny spray of windex and now several of the keys dont work
I think the dirt got stuck under them. Try to repeat the procedure in the affected keys. Hopefully you have still plenty of WIndex.
Apr 13, 2010 | LG Keys-U-See Keyboard
Cleaning keyboard, spills, how to clean it.
Power down, remove battery, blow the keyboard with compressed air from a can you get at an office supply store. Do not spray any liquid cleaner of any kind directly on the board, spray a cleaning solution on a microfibre towel but do not saturate it, gently run the towel up and across the keys, when you are finished cleaning, blow the keyboard dry with more air. If you are satisfied of the dryness of the board, re-install the battery and power it up.
Oct 01, 2009 | Toshiba Tecra M3 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
