Question about Dell 3100cn Laser Printer
Smurge when printing
My printer prints fine, but sometime (mostly on red ) you will see a smudge. Sometimes they are small, but very noticeable, and it's in random areas of the printed paper. Does anyone have suggestions. Printing color 8.5 x 11 full page:
2.5 in from top of page I notice of pattern of nicks on the page 1/8 to 1/2 inch across the page mostly on the left 6 inches of the page
  • 3,037 Answers
Smudges usually will indicate a drum problem (your toner cartridge) on a laser printer. If you pull it out you should see a flap that will move back and forth. Moving that flap will show you a cylinder which is the drum. If it looks worn, then it will have to be replaced. It may be hard to tell if the drum is worn down.
During the lifetime of the printer, the drum needs to be periodically replaced as its surface wears out and print quality deteriorates which is what is happening with your printer.
So you will need to try replacing the cartridge and see if that solves your problem, if it doesn't then you will have a spare and I can further direct you to what to look for.
please let me know how this goes and good luck
Posted on May 08, 2008
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    Please don't forget to let me know your feedback about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, my solution needs to be rated.
    Otherwise, let me know if you have further questions and I would be more than happy to help.
    Thank you
    Guru:
  • 1,342 Answers
Read a previously submitted solution to this issue HERE
    Master:
  • 555 Answers
A manual and troubleshooting guide for your printer can be found here.
  • Matt Jurach
    Matt Jurach May 08, 2008
    It sounds like the transfer roller might be damaged. How long have you had this printer, and has the fuser been replaced yet?
  • Matt Jurach
    Take a look at Dell's Print Quality Problem guide. Do any of those pages look like your?
    You can use the "Customer Mode" diagnostic menu on your printer to print a Print Quality test page in order to more accurately view the printing problem symptoms.
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
PRINTING IMAGES ON CD'S/DVD'S - SMUDGES / i865
After looking at a picture of the CD you were printing to, I see the problem. The printer is trying to print blue ink on the middle of the CD, where the hole is. The problem is, since there's a hole that ink is going through and getting onto the rollers in the printer. It's then transferring back to your media as it moves through the printer. It's C shaped because you're only printing on about half of the hole. There are two ways to fix this. Either put a round piece of tape over the hole to cover it (and thus the paper will be printed on), or change your image so it doesn't print to that part of the CD. I'd suggest the latter, as it will look neater when you're done.
Oct 01, 2007 | Office Equipment & Supplies
Since conecting my Lexmark P4350 to a different pc it is sometimes only printing half a page and sometimes the print is smudged. can you suggest anything.
Make sure that the printer driver is properly installed. Please visit the Lexmark website to download and install the Lexmark P4350 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. After the install process is complete, try to print again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark P4350 All-In-One InkJet Printer
Smudged on right side
If cleaning the print cartridge with the built in slide does not work then you can lightly shake it. it may need to be replaced. Also the cleaning of the drum with denatured alcohol will clear that up sometimes.
Nov 30, 2009 | HP LaserJet 4 plus Printer
Changed cartrige, now have smudge lines on paper
please check the cartridge and see if it is the recommended one the printer..
if it is .... remove it ,clean the print mouth, re fix it and try printing...
sometimes refilled cartridges also give the same problem. please check that too.
May 26, 2009 | HP LaserJet 1020 Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
HP Deskjet 3940 will only print job in que when computer is restarted?
hi there, you do have a probl;em at your printer, try to test another printer to your unit and if still same problem you have a software problem or else your printer board is mulfuctioning. ty
Dec 24, 2007 | HP DeskJet 3940 InkJet Photo Printer
Dell 3100cn Laser Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
