Question about GE Spacemaker JVM1640SJ Microwave Oven
No power, nothing works. - GE Spacemaker JVM1640SJ Microwave Oven
    President:
  • 2,702 Answers
This is likely to be a blown fuse inside the microwave,,,
they dont normally blow for nothing,,you may have a biger fault in there,,,,,the fuses are not the normal size,,,you may find it hard to get them
Posted on Aug 30, 2010
Display shows "=SE-", and do nothing
"SE" means = sensor error, try to dry it out with a hair dryer, if not working, you have to replace the sensor
Jul 29, 2012 | Samsung SMH9151 Microwave Oven
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Yesterday the microwave was working fine, this morning nothing at all...No power at all. I have checked the circuit breaker and everything is fine. The oven below it is on the same breaker and it works...
it sounds like the internal fuse has blown. if your handy, it can be done , however,,MAKE SURETO
DISCONNECT THE POWER SOURCE BEFORE BEGINNING. if your not 100% comfortable
have a trained technition service the unit...
Nov 20, 2010 | Whirlpool GH7208XR Convection / Microwave...
Microwave has no power
inside the microwave there is a low voltage power supply that powers the computer and display ... that is not working in your case .. if there is no low voltage power then nothing else will work .. there are several possible causes .. you can have a blown fuse on the low voltage power supply board (usually the main and only board) ... there is also a thermal fuse ... if the microwave magnitron got exceptionally hot then it could trip the thermal fuse .. this would kill power to everything else ... high magnitron tempratures can be caused by blocked air flow or running the microwave with nothing in it ... once the thermal fuse is tripped it has to be replaced ...there is also an over temperature switch that simply shuts off the power until the system cools , but this is self reseting unless it goes bad .. inside the microwave oven electronics are the most dangerous combination of high voltage and high current you will likely encounter in your life .. you simply have to know what you are doing in there ... this combination can be fatal in a fraction of a second ... your problem is inside there where its dangerous .. the low voltage supply and computer are not dangerous but the voltage they control is .. .. all parts that can cause this trouble are available for most microwaves so yes its repairable but think twice before opening .the case .. there are microwave repair centers around here .. the cost may or may not be reasonable since new microwaves are available for really good prices right now ....
Aug 18, 2009 | Microwave Ovens
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
No power - Nothing happens
if you have power at the outlet and the internal fuse is okay, I would say you have a problem on the control board. We repair these nationwide for $32.50. Please see my profile for the Web address: http://tinyurl.com/yzjozk
Jan 08, 2007 | Emerson MW8107WA Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
